69 Gto pinion seal woes - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-27-2014, 12:58 PM Thread Starter
Hi all, I have a 69 Gto and am having a hard time with pinion seal sizes
diff is an 8.2 Pontiac, with a yoke diameter of 1.942 and a housing bore diameter of 2.695, all the listings for this are are for housing bore diameter of 2.766 that's way to big and collapses the seal has anyone else had this problem?
vintagetrans1 is offline
post #2 of 5 (permalink) Old 08-27-2014, 02:51 PM
Welcome to the forums.
Sounds like maybe it's not the original axle assembly. I would check the stampings and decode from there.
post #3 of 5 (permalink) Old 08-27-2014, 04:14 PM Thread Starter
Thanks Rukee, good thought, housing number is 9799202-cfd- 1969 gto 10 bolt, the cars a 69 Judge with 53000 miles, I have never seen this before, I went up in the catalogs several years and back several years including Chevrolet buick and olds most buick, olds and Pontiacs use the same seal......arghhhhh
post #4 of 5 (permalink) Old 08-27-2014, 06:39 PM
The part stores (who know what they are doing) should be able to get you a seal using your I.D. & O.D.
post #5 of 5 (permalink) Old 08-28-2014, 09:30 AM
GTO70455's Avatar
Somewhere between 1969 and 1970 Pontiac did a running change to the 10 Bolt rear. Back in the day it was called big bearing or little bearing rears In the old Pontiac parts book they were separated by build date. I have had friends with the same problem. Somewhere in time the new parts books have lost this minor detail, and only list 1 rear. The early rear had the big bearing, the late rear had the small bearing. The seals were different to. The best way today is measure the seal and contact the seal company and get sizes. If the bearings need changing get the Timken number off the bearing and look it up that way.
GTO70455 is offline
Viton Seal leaked terrible. Installing Graph Tight Seal timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-08-2013 01:17 PM
Sway Bar Links, CV Boots, and Pinion Seal apfeif3 Drive train, suspension, alignment and brakes. 0 05-29-2013 04:05 PM
What is the Right Pinion Seal? Wob 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-30-2012 03:54 PM
Why is my rear pinion seal leaking? jimchevy 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 04-01-2012 06:35 PM
Diff. pinion seal leak @ 11.5K cat1055man Drive train, suspension, alignment and brakes. 3 12-13-2007 05:27 AM
