69 GTO speedometer trouble need help - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-19-2017, 07:36 PM Thread Starter
Hi Guys I have a 69 gto that my speedometer is running about 10 miles a hour to fast My output shaft has 18 teeth metal gear my what I call cable gear has 38 teeth I went to a calculator and it said I need a 44 tooth cable gear so I bought it and then I needed to change the housing so I bought that now here is my problem I put everything back together the cable gear wont move I have in and out play so I know its not tight any where when I loosen the bolt it starts to turn I measure the OAL withthe gear in it and its the same as my old one I just dont know what wrong maybe someone had this problem any help will be greatly appreciated
trainman115 is offline
post #2 of 2 (permalink) Old 02-20-2017, 11:52 AM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
That answer was posted in your other thread. You need the 40-45 tooth adapter.
64GTOConvertible is offline
Gto trouble irelandGTO 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 20 05-08-2016 11:09 AM
68 GTO speedometer repair 1coolduck 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-30-2014 09:55 PM
where can i get a 66 gto speedometer?? Mr66GTO 1964-1974 Tempest, Lemans & GTO General Discussion 4 05-11-2009 06:08 PM
gto trouble. crazy8ray 2004-2006 GTO General Discussion 20 06-10-2008 11:29 AM
