69 gto suspension mods ????? - Pontiac GTO Forum
post #1 of 17 (permalink) Old 08-19-2009, 05:16 PM Thread Starter
harp's Avatar
what can i do to my showroom stock numbers matching gto to cut out some of the bounce and roll? stiffer shocks? sway bars? it runs great but it would be more fun if it handled better. thanks
harp is offline
post #2 of 17 (permalink) Old 08-19-2009, 05:57 PM
67goatman455's Avatar
It depends how far you would want to go with it, but yes an adjustable or performance shock would be a good start or performance sway bars especially if your car did not come with a rear one. I don't know how crazy you would be about the idea, but a lowering spring can help A LOT as well. Just switching to a 1" lowering spring from Hotchkis i noticed a huge gain in handling quality, but if you do switch springs i would highly suggest a performance shock as well.
If you really want to get some technical data and firm responses on what to do check out pro-touring.com
67goatman455 is offline
post #3 of 17 (permalink) Old 08-19-2009, 06:33 PM
Quoted: 102 Post(s)
KYB gas-adjust shocks, a slightly bigger front sway bar, and a rear sway bar with the boxed contrrol arms will help a LOT without hurting the ride or value of the car.
post #4 of 17 (permalink) Old 08-19-2009, 09:30 PM Thread Starter
harp's Avatar
thanks for the info, the rear seems tighter than the front, much less bounce and sway,the front recoils twice after pushing down on the fender and it sways back and forth left and right. i'd like to tighten up the front, feels like i'm driving a 350 hp. stagecoach
harp is offline
post #5 of 17 (permalink) Old 08-19-2009, 09:52 PM
68greengoat's Avatar
When were the springs last replaced? That can make a big difference too. You may have original front springs in it since they're alot tougher to change than the rears. Rears may have been replaced. If the housing on the front shocks have spiral indentations there's a good chance they're original. I have first hand knowledge with those. I couldn't believe it that I was the first one too change my front shocks.... Shocks and springs made a big difference in handling. Sway bar and end link bushings could be shot too and need replacing...
68greengoat is offline
post #6 of 17 (permalink) Old 08-20-2009, 09:10 AM
Quoted: 102 Post(s)
Good point, GG. I had assumed his suspension was refurbished, but stock. Yes, very important to refresh the bushings, tie rod ends, ball joints, etc. and coil springs as well. Not fun, not really cheap, but do it once and you're good to go another 100k miles! Those lower control arm bushings are no fun at all!!!
post #7 of 17 (permalink) Old 08-20-2009, 11:13 AM
Hello, we offer several different suspension parts as well as packages to increase the handling and performance of your a body. We offer sway bars, upper and lower control arms,upper and lower a arms, lowering springs, as well as bilstein, and QA1 pro coil or regular adjustable shocks. Here is a link to our site. Also if you interested in a package but don't see one that has the parts in it that you want i can make you a custom package with the exact pieces that you need. Take a look at what we have to offer and if you have any questions about any of the parts please give me a call.
BMR Fabrication Inc.
Thanks,
Joe Kubiak
Sales / Tech
BMR Fabrication
813-986-9302 Phone
813-986-8055 Fax
[email protected]
www.BMRFabrication.com
BMR Sales is offline
post #8 of 17 (permalink) Old 08-20-2009, 12:10 PM
Quoted: 102 Post(s)
I think that the above aftermarket items, while excellent for high performance usage and improved handling, would both hurt the value and ride quality of the original, numbers-matching car in question. Harp wants to restore his vehicle's ride and handling qualities, I think. Turning it into a modified canyon carver, (always an option!) is not the main focus here. I've driven highly modified A bodies, and they handle like a new Corvette. Unfortunately, they ride very stiffly and are uncomfortable on long trips.
post #9 of 17 (permalink) Old 08-20-2009, 02:25 PM
YOU ARE !!
Eric Animal is offline
post #10 of 17 (permalink) Old 08-20-2009, 04:15 PM
xcmac26's Avatar
Quoted: 5 Post(s)
buy/add the modern stuff, keep the old in a box. Swap back if you ever sell to retain value?
xcmac26 is offline
History of the GTO, GOAT Name Origin, and Tiger Theme GTO JUDGE In the News 2 10-13-2008 03:43 PM
65 GTO Front suspension Indy1K 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-24-2008 06:30 AM
Play Time with new Mustang Shelby LTChappa Racing and Kill Forum 24 04-19-2008 11:14 PM
GTO a real tire shredder? 05GTO In the News 52 10-31-2007 02:09 PM
