69 Lemans Sport Gas Tank Replacement - Pontiac GTO Forum
 1Likes
  • 1 Post By PontiacJim
post #1 of 8 (permalink) Old 11-22-2017, 01:26 PM Thread Starter
shimelhoch's Avatar
Quoted: 5 Post(s)
Hello Everyone,
I am in process of replacing the original gas tank on my 1969 Pontiac Lemans Sport. Engine is a 350 with TH350 transmission. The car has factory AC. I am trying to make sure I have all of the ports and wires accounted for. Not sure what #1 and #4 should connect to so any guidance would be appreciated. Please see attached picture.
1. ?
2. Return hose which connects to the fuel pump (for cars with AC)
3. Fuel Line which connects to the fuel pump
4. ?
5. Ground?
shimelhoch is offline
post #2 of 8 (permalink) Old 11-22-2017, 03:50 PM
Sure reads like you have a '70 Calif emissions, or '71-72 Pontiac A-body gas tank that you are trying to fit in your '69 LeMans (or Custom S ) convertible. You could have a local radiator shop swap filler necks & just cap off the two extra vent lines for the EEC canister. It's either that, or return the new fuel tank.
post #3 of 8 (permalink) Old 11-22-2017, 05:06 PM Thread Starter
shimelhoch's Avatar
Quoted: 5 Post(s)
I think its the correct tank. It has all the same connection points and number of ports. I am just not sure the previous owner had everything connected properly and want to make sure its right before I re-install the tank.
post #4 of 8 (permalink) Old 11-22-2017, 06:13 PM
Quoted: 390 Post(s)
Not a California emissions tank.
1- filler tube vent - has a rubber hose on the nipple and then a "J" shaped steel line that inserts into the rubber hose and hooks under the trunk floor just above the nipple.
2 -1/4" gas return line
3 - 3/8" gas line
4 - tank vent - should have a hose that curves to the left (drivers side) then up along side the tank strap. On the end of the hose is a vapor filter. OPGI has one, does not look factory according to my service manual, but will work. I believe it is really for a Chevelle. https://www.opgi.com/gto/CH28013/
5 - Ground
Your 1969 Pontiac Service Manual should show you all this under the "FUEL TANK AND EXHAUST SYSTEM" section and how the lines run.
shimelhoch likes this.
post #5 of 8 (permalink) Old 11-22-2017, 06:27 PM
Jim, i can think of no stock pre '70 A-body gas tank has more than a supply line & a return line. Very strong possibility, the tank is a '71-72 with a '69 filler neck sweated on.
post #6 of 8 (permalink) Old 11-22-2017, 06:31 PM Thread Starter
shimelhoch's Avatar
Quoted: 5 Post(s)
Thanks PontiacJim. Sounds about right!
post #7 of 8 (permalink) Old 11-22-2017, 06:37 PM
Quoted: 390 Post(s)
I am reading and looking at the line drawings with exploded views right out of my 1968 Pontiac Service Manual, so if the '68 had the same tank as the OP, I can only assume that the 1969 was also fitted with same.
post #8 of 8 (permalink) Old 11-24-2017, 02:45 PM Thread Starter
shimelhoch's Avatar
Quoted: 5 Post(s)
Installed the tank today. It fit pretty well and only need a few minor adjustments. the OPGI tank has some excess material at the seams which the original did not. Once I bent that out of the way so the straps would sit more flush, everything bolted together nicely. Thank you again everyone for your help on this. The Lemans is running nice...
Thanks for everyone's comments!
Gas Tank Replacement wings012345 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 07-07-2015 11:39 AM
1971 GTO/LeMans gas tank mrvandermey 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-11-2013 02:34 PM
1967 Lemans Gas Tank replacement DennyOH 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 11 01-06-2012 08:20 AM
Aus gas tank vrs USA tank? GO-GTO! Service, Maintenance and Technical Discussion 23 03-03-2006 11:45 PM
