69 weird electrical problem - Pontiac GTO Forum
post #1 of 7 (permalink) Old 04-12-2014, 01:04 PM Thread Starter
69GTOCONVLOVER's Avatar
Hi guys; we have this weird electrical problem. When all 4 brake lights work, the windshield wipers don't. If I then leave the wiper switch on the wipers work after a while and the inner left brake lights don't.
Thanks, Martin
69GTOCONVLOVER is offline
post #2 of 7 (permalink) Old 04-12-2014, 04:26 PM
jmt455's Avatar
First thing to check: Grounds!
Check all the grounds for your rear lamps and also make sure the dash/IP grounds are in good condition.
Also make certain your engine-to-body, body-to-frame and engine-to-body grounds are good.
I install redundant ground cables from the taillight housings to the frame rail on these cars; that usually eliminates the tail light problems.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #3 of 7 (permalink) Old 04-12-2014, 06:06 PM
+1 on the grounds. Also don't just assume because there is a ground cable it is a "good" ground. Take them loose and clean off any rust, paint or corrosion so it makes good contact. I also installed a large extra ground cable from my block to the frame.
Good luck! I know chasing electrical gremlins is challenging.
post #4 of 7 (permalink) Old 04-12-2014, 06:50 PM Thread Starter
Checked the grounds and I just started laughing See for yourself
post #5 of 7 (permalink) Old 04-12-2014, 07:40 PM
Quoted: 23 Post(s)
+1 on the block to frame cable.
Instg8ter is offline
post #6 of 7 (permalink) Old 04-12-2014, 09:59 PM
jmt455's Avatar
Yeah, that might be part of the problem...
1968 Pontiac GTO
jmt455 is offline
post #7 of 7 (permalink) Old 04-13-2014, 04:43 PM
I think you may have gotten close to the problem HAHA........You may want ot check a few more things cause that may not be the only one. ????******
rexs73gto is offline
Weird problem..Can you help me please? timwal6 Service, Maintenance and Technical Discussion 8 05-14-2009 07:09 AM
Weird Alarm Problem Church Interior Discussions 15 04-12-2008 01:37 PM
weird problem with my 04goat 06BLUEGTO Service, Maintenance and Technical Discussion 2 09-05-2007 11:03 AM
Weird Problem DriftingIsGay 2004-2006 GTO General Discussion 13 03-17-2007 09:04 AM
