70 gto posi unit gearing - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-23-2018, 05:43 AM Thread Starter
Any other way to check original gearing?
My70gto is offline
post #2 of 2 (permalink) Old 09-23-2018, 03:41 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
original gearing ??
or
whats in your car now ??
scott
pop the cover off
and look on the ring gear on the originals ... tooth count is stamped in the ring gear edge
if you dont know anything about it
drain it .....
buy a gasket and 2 quarts of 80 90 valvoline and fill till it runs out the fill hole...
wire brush or power wash the seal area BEFORE taking the cover off
and around the filler hole plug so no debris gets in
yah theres stamps on the tube and casting numbers ... and yopu can spin the tire and count and divide ..............
just pull the cover... change the lube make sure to clean the oil out of the bottom of the carrier
and wipe the bottom floor of the housing clean with brake clean on a rag ....and a screw driver
all the heavys with fall and be there layin on the bottom
BLK69JUDGE is online now
Posi unit help Wendt69 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 21 01-26-2016 07:37 PM
posi unit for 66 tonyli 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 17 11-12-2015 04:42 PM
Noise From Auburn Posi Unit 68Resto-mod 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 04-10-2015 10:09 PM
will a 8.2 10 bolt posi unit out of a chevy fit in a bop 8.2 rear? danthepontiacman 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 09-04-2012 01:08 PM
69 GTO 10 bolt non-posi convert to 12 bolt posi AzStateFan 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 09-12-2009 04:34 PM
