71 ignition lock removal - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-20-2008, 03:12 PM Thread Starter
Hi gang, I am having trouble pulling the ignition lock assembly. I understand from the shop manual tha there is a release that must be depressed. I have submitted a photo in hopes someone has pulled theirs before and might help me. The book says to insert a screwdriver or knife blade in the slot next to the turn signal hold down boss. Not sure which one is correct. I tried #1 and #2 but can't feel the release. thanks for any help
Baknaz is offline
post #2 of 4 (permalink) Old 07-20-2008, 04:16 PM Thread Starter
Well, found an illustration in manual that shows a flat metal ruler stuck in the slot #2. I just can't seem to find the release.
Baknaz is offline
post #3 of 4 (permalink) Old 07-20-2008, 04:43 PM
Try this, Put key in switch, turn to on and the latch that needs to be depressed should be seen in slot 2.
Here is an image of the lock;
Good Luck,
05GTO is offline
post #4 of 4 (permalink) Old 07-20-2008, 06:02 PM Thread Starter
Thanks, Got it. From the scratches on the cylinder, looks like i was actually hitting behind it for awhile. Works perfect but broke the black plastic shaft that the horn spring goes in, while putting the wheel back on. I guess i'll try and super glue it. Thanks again
Baknaz is offline
Lock Problems - Anyone else? HELP? gtogirl Service, Maintenance and Technical Discussion 12 05-25-2017 08:21 PM
Passenger Side Door Lock awsumvet Interior Discussions 1 12-05-2007 03:24 PM
Remote key door lock failed DAH GTO Interior Discussions 3 10-25-2006 05:15 PM
Passenger Door lock question kevracer Interior Discussions 5 10-20-2006 06:33 PM
Lock and Roll Financing Nov 2004 skier757 2004-2006 GTO General Discussion 0 01-30-2006 07:11 AM
