71 LeMans Sport 2nd attempt to post - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-24-2011, 06:40 PM Thread Starter
Pontiac Badger's Avatar
just got a partially started (trim and vinyl top removed) 71 LeMans Sport 350 took a couple days to replace rusted rear quarter panels weld and lightly bondo weld seams.need to pull bumpers and finish prepping for primer.
How do you know if motor and tranny are #'s matching for car? they both run good but I would like to know if they are original like I was told.
Pontiac Badger is offline
post #2 of 3 (permalink) Old 07-25-2011, 09:37 AM
Thumpin455's Avatar
The trans has a tag stuck to it with a code and a partial VIN. Easy to spot if you clean it off. The block has a VIN stamped in it right next to the timing chain cover on the passenger side. Its right around the spot where the lower heater hose connects. If those numbers match the VIN on the dash, then they are the original parts.
Thumpin455 is offline
post #3 of 3 (permalink) Old 07-25-2011, 09:30 PM Thread Starter
huge thanks
Just looked motor matches .
Cant find tag on tranny though, possible local would help. thanks.
Picture posting attempt 68OldGoat Test Forum 5 08-17-2013 10:49 PM
Post to sport coupe conversion? PontiacDave 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-22-2009 09:30 PM
1971 Lemans Sport onebadvette 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-05-2009 05:45 AM
