!969 GTO Hood Latch Issue - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-21-2015, 09:29 AM Thread Starter
I was just trying to pop the hood to check the oil and inspect the engine and it won't completely open. Seems the driver's side releases but the left side is tighter. I cant pull it up far enough to release the latch and lift it.
Is this a common problem? How can I get the darned thing open now?
Thanks for any help or advice in advance!!
saturnkk is offline
post #2 of 8 (permalink) Old 10-21-2015, 03:58 PM
My 68 has same issue. I pull once and hood pops, I have to give it a really good "push" and "pull" again while pushing down on hood slightly to release. I am guessing a common problem. Least of my worries; to fix so it works flawlessly right now. Hope this helps.
shoeman68 is offline
post #3 of 8 (permalink) Old 10-21-2015, 04:05 PM Thread Starter
Thanks ill try pushing down hard while I release...
saturnkk is offline
post #4 of 8 (permalink) Old 10-22-2015, 07:39 AM
SANDU002's Avatar
That technique works for me on my '70. Easier than adjusting the bracket.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #5 of 8 (permalink) Old 10-24-2015, 05:41 PM
Mine too. When I pull the latch the spring pops the hood up but the 'safety' catch catches it. I have to push down on the hood just enough to take the pressure off the catch, then pull the release out again to get the hood the rest of the way up.
I'm so used to doing it this way that I thought it was 'normal'
post #6 of 8 (permalink) Old 11-02-2015, 05:43 PM Thread Starter
...just wanted to report back that that did it. Thanks guys!!
saturnkk is offline
post #7 of 8 (permalink) Old 11-11-2015, 08:52 AM
is there a way to adjust it to open it all way with out holding down on it thanks
calray is offline
post #8 of 8 (permalink) Old 11-11-2015, 12:11 PM
Dunno Calray, maybe --- but like I said I'm so accustomed to opening my hood now that the motion is second nature. It doesn't bother me. If there *IS* a documented adjustment procedure, I'd expect to find it in the applicable Fisher Body factory manual for your car.
1969 GTO hood latch DSW 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-20-2013 09:46 PM
hood latch spring Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 11-18-2010 09:25 PM
Hood Latch on a 65 injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 24 04-22-2010 10:01 AM
Hood Latch Fell Off! Goatman455 1964-1974 Tempest, Lemans & GTO General Discussion 14 06-12-2009 10:02 AM
1967 GTO Hood Latch Assembly nevermind8285 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-25-2009 08:48 PM
