Accel HEI supercoil (140005) - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-08-2009, 10:03 PM Thread Starter
Hey Guys
I got a slight problem maybe you can help with.
When i get on the gas i start getting a popping/loading up sound and hesitation around 4k rpm.
I'm sure the plugs are fouled because they foul out like its thier job in this engine.
So i called the Motor shop today asking about trying new plugs, they said to try a hotter plug instead of the colder ones i use due to it being a 12 to 1 comp ratio.
I just cruise around town, not racing so the rpms never really get up above3k to 4k anyway
He said a hotter plug would burn more of that carbon up like the way a glow plug can handle desiel, which kinda makes sence but scares me about pre-ignition.
They also told me to swap to a MSD 6AL system but i think he assumed i was running stock points not a HEI upgrade(Accel 140005).
Ok so here is the question is this Accel HEI trash or is it fine?
Do i need to and a controll box like a MSD 6AL?
im not sure the Accel super coil can use a external box or not.
And should i try the hotter plugs?
(if you want to see engine spes i have detail listed in the forsale thread under 69 built 455 btw)
Thanks again
Silky58
silky58 is offline
post #2 of 3 (permalink) Old 08-09-2009, 11:08 PM
What year. Engine? Do you have 12V to the positive side of the coil? Try this question on PY forums.
I hve 68 up graded to Pertronix. Had to plce jumper wire behind ignition switch from R1 to R2. HEI need 12 V.
wallawallaron is offline
post #3 of 3 (permalink) Old 08-10-2009, 12:55 AM Thread Starter
its a 1969 gto with a 73 455, like i said in the post i have full engine details list under the for sale section.
the hei is alrdy on i was wondering if i needed to add a control box, add if i should try a hotter plug.
thx for the reply tho
silky58 is offline
HEI instead of points auburnconsulting 1964-1974 Tempest, Lemans & GTO General Discussion 2 05-04-2009 03:25 PM
Engine code and date discrepancy - HELP!! Mcantw 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 16 02-13-2009 09:04 PM
