Accuracy of gauges... - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-16-2014, 06:39 PM Thread Starter
I recently picked up a 1967 GTO with a 1970 (i believe) Pontiac 455. It was a frame off restoration. Most of my mechanical skills have been to replace the oil and filter.
Driving it the other day with the temperature 90+ degrees in stop and go traffic, the temperature climbed up and hit 250 on the temperature gauge. The dash gauges are either original or reproductions. Lowest temp, 100 Middle 210 and high is 250. Graduations in-between those which would be 155 and 230.
Today, I flushed the coolant out and replaced it. Tested it and measured with a pretty accurate infrared thermometer to see when the thermostat would open. It opened when the temperature (infrared measured) was a bit higher than 160. I was looking at the dash gauge every few seconds and noticed when the infrared measured 150-160, the gauge measured about 210. The dash gauged climbed all the way and pegged 250. At that time I infrared measured both sides of the thermostat and the reading was close to 180. At that point I felt the radiator get hot and when I looked back at the dash gauge, it was coming down from 250 to settle around 210.
So, I'm looking at some aftermarket gauges. Something like these.
1964-73 GTO Autometer Gauges, Autogage 2-5/8" White black holder @ OPGI.com
Do the gauges like I linked above come with sensors? Are there different sizes or are they standard sizes. If they come with sensors it appears I can either replace the one where it is now or is that another place to the left of the thermostat where I can place a new one?
Here is a photo of my thermostat.
VA67GTO is offline
post #2 of 5 (permalink) Old 05-16-2014, 07:34 PM
RunninLeMans's Avatar
Generally those gages come with a sensor bulb and threaded fittings that go right back in where your existing electrical sensor is, or you can use the other bung (threaded hole) and leave the stock one in place. You might find the 2.5/8" gages a little big - I also ordered them at one point and they blocked most of the view of my right foot and gas pedal, I returned them and like the 2.1/16" size much better.
http://www.summitracing.com/parts/atm-2397
RunninLeMans is offline
post #3 of 5 (permalink) Old 05-17-2014, 07:55 AM Thread Starter
Good suggestion on the 2 1/16 gauges. I took a compass and drew 3 at the larger size and 3 at the smaller size and I think I'll like the 2 1/16 size better.
Anyone know if the gauges swappable? Meaning can I move the gauges around so I'd see engine temp on the left, then oil pressure and lastly on the right, voltage?
VA67GTO is offline
post #4 of 5 (permalink) Old 05-17-2014, 08:34 AM
Yes, you can move the gauges to any position you want.
I haven't used this guys service but he might be someone to talk to too get your factory gauges in working order and keep your car looking stock.
Pontiac G.T.O Olds Cluster Gauge Restoration
post #5 of 5 (permalink) Old 05-17-2014, 12:29 PM
Quoted: 117 Post(s)
I was able to get the temperature gauge reading calibrated on my original '65 GTO rally cluster by talking to Pete Serio. He referred me to Lectric Limited, which has the correct value temp sensor for our Pontiacs. I had been running a generic NAPA unit, and the reading was 20 degrees too high over actual temperature. Installing the correct sending unit fixed the problem. The car now runs 180-195, instead of the previously indicated 200+. Also, dash grounds can affect the gauge readings. A bad or weak ground will make them read much higher, especially with the headlights on.
gauges Bigalsworth 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 01-24-2014 05:04 PM
'67 Gauges..... Uly49 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-15-2011 06:43 PM
New Gauges khinton 1964-1974 Tempest, Lemans & GTO General Discussion 10 04-22-2010 06:24 PM
Gauges Bday6262 2004-2006 GTO General Discussion 9 07-20-2007 07:17 AM
Anyone have these gauges? LIVEVIL 2004-2006 GTO General Discussion 15 09-13-2005 11:50 PM
