Adjustable seating?? - Pontiac GTO Forum
post #1 of 15 (permalink) Old 01-12-2010, 03:16 AM Thread Starter
xconcepts's Avatar
I'm contemplating changing out my original seating in my 66 to something that would still be close to original but have the adjusting tilt feature. When did the GTO go to adjustable tilt seating and how close to looking original would I be looking at? Also, would it be a simple swap out or am I looking at having to mod the railing?
-X
xconcepts is offline
post #2 of 15 (permalink) Old 01-12-2010, 12:31 PM
Quoted: 102 Post(s)
The GTO had an optional reclining passenger seat starting 1966. The optional headrest equipped seats usually had this option. You could not get the recliner without the headrest. Unfortunately, it was only available for the passenger side!! Maybe you could find one and convert it. Be prepared to spend big $$$. In more than 30 years of GTO'ing, I've run into ONE early GTO that had this option, and it belongs to a gentleman on this forum!!! I've never seen any of these seats in my many junkyard crawls.
post #3 of 15 (permalink) Old 01-13-2010, 08:28 AM
X, I am pretty sure that 67 GTO had apower seat option that went forward/back, and up/down called 4way. I am not sure it tilted also.....There was a 6 way option for bench seats.....I had a 73 Riviera with bucket seats they were 6 way...perhaps you could find a version of this system and use it...I will look into this further and post again. Eric
Eric Animal is offline
post #4 of 15 (permalink) Old 01-13-2010, 08:37 AM Thread Starter
xconcepts's Avatar
Eric, really just looking for the tilt since when I ride in the GTO being as tall as I am My head just about hits the roof. The up and down would work, but I'm just trying to get the seats to decline.
post #5 of 15 (permalink) Old 01-15-2010, 09:57 AM
I think the power tracks MAY actually make the seat ride higher. I will try to find out. You may have to "customize" a set....... ppurfield is about 6'8" ! He put 2004-2006 GTO seats in his 67, and moved them back some. they are nice looking seats. Send him a PM and get some feedback from him. I am a shorty 6'1" Eric
post #6 of 15 (permalink) Old 01-15-2010, 04:14 PM Thread Starter
xconcepts's Avatar
Shoot your taller than I am, but I still seem to only have about an inch - inch/half to the roof.
post #7 of 15 (permalink) Old 01-15-2010, 10:30 PM
67 Basket Case Restorer
Too Many Projects's Avatar
You must be long in the torso and short legged. My wife is 1" shorter than me but her inseam is 3 " longer !! She's all legs. When she sits in her car, she looks short but when I get in her car, I have to move the seat forward to reach the pedals.
There are aftermarket brackets now that position the seat rearwards a couple inches by bolting to the existing floor brackets and then the seats bolt to the extenders. Don't know if the extra leg length would help but the seat tilts back more in that position too. Heck, put a half inch spacer under the front legs with longer bolts for the tilt and see if that helps.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #8 of 15 (permalink) Old 01-16-2010, 08:11 AM
I actually did the opposite in my 67...spine problem causes me to have to sit up straight. I put shims under the rear seat mounts....worked very well.
post #9 of 15 (permalink) Old 01-22-2010, 05:09 PM
BYTOR84's Avatar
hey does anyone have any more info as to where I could get those extended brackets?? I'm 6 ft 7 in and I could use the extra leg room. (36 inseam) But I also solved the hitting the head on the roof problem.......I got a convertible....LOL
BYTOR84 is offline
post #10 of 15 (permalink) Old 01-23-2010, 04:23 PM
You can fabricate them yourself or have a metal shop do it...fairly easy project
Hal 12 Way Adjustable Shocks tbyrne Drive train, suspension, alignment and brakes. 0 01-21-2007 07:28 PM
Adjustable Radius Caster Kit, a question for one skilled in the craft of alignment 04m6_ca Service, Maintenance and Technical Discussion 0 12-30-2005 03:13 PM
