Advice on loose steering for 1968 Tempest - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-17-2017, 12:54 PM Thread Starter
Hey guys
My Tempest has really loose steering?
Advice on tightening up this feeling i.e steering box centering or other cheap fixes?
uptoncs is offline
post #2 of 5 (permalink) Old 07-17-2017, 03:39 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
Depends on what's wrong with the steering. Are all the individual parts tight? Wheel bearings good and adjusted properly? What do you have for tires? Sway bar links/bushings in good shape?
LOTS of little inputs here...
64GTOConvertible is offline
post #3 of 5 (permalink) Old 07-18-2017, 11:01 AM
pjw1967's Avatar
MY '67's front end wallowed all over. Turns out it was the control arm bushings.
pjw1967 is offline
post #4 of 5 (permalink) Old 07-19-2017, 04:55 AM
GTOJUNIOR's Avatar
Quoted: 65 Post(s)
If you look in the service manual there is a procedure to tighten up your gear box, However depending on your "LOOSE" condition it may just be worn out.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #5 of 5 (permalink) Old 07-19-2017, 06:26 PM
Also, check the rag joint that attaches the steering column to the gear box,
05GTO is online now
Loose Steering evanpatchay Drive train, suspension, alignment and brakes. 0 04-29-2015 07:29 AM
Loose Steering Red2005Goat 2004-2006 GTO General Discussion 3 07-26-2013 02:26 PM
My Steering Wheel Is Loose! freeze916 Service, Maintenance and Technical Discussion 4 07-07-2010 08:05 AM
loose steering wheel 04m6gto Drive train, suspension, alignment and brakes. 9 07-08-2007 10:06 AM
steering too loose after alignment? gpro102 2004-2006 GTO General Discussion 6 08-30-2005 06:16 PM
