Age Old Story - Overheating..... - Pontiac GTO Forum
post #1 of 11 (permalink) Old 08-30-2011, 03:43 PM Thread Starter
Jim
Jim's Avatar
Well, it seems to have gotten worse. 67 GTO is overheating to the point it is boilng out. Now, I know the Texas heat is killing us but I'm talking about early in the morning when its only 130 degrees (OK, only 85). I had the radiator cored out a couple of years ago so I don't think its that. It has another new thermostat. I used a 160 this time. Flow seems to be good.
SInce I was going to do this eventually I ordered an aluminum radiator from Ames along with the FlowKooler water pump and the associated seals, backer plate, etc.
Any other thoughts or comments?
Jim
Jim is offline
post #2 of 11 (permalink) Old 08-30-2011, 04:23 PM
facn8me's Avatar
I'd like to see what the plate and water pump impeller looks like when ya pull it apart.
https://www.gtoforum.com/signaturepics/sigpic18842_1.gif
1966 Pontiac Lemans Convertible
389 tri power
facn8me is offline
post #3 of 11 (permalink) Old 08-30-2011, 04:24 PM
Pontiacpurebrred's Avatar
Well same thing as always, timing, carb tuning, gas quality vs. compression ratio of the car and what kind of shape is your radiator hoses and fan shroud in? Oh and distance of shroud from radiator and distance of fan from radiator and is there any air flow around the shroud?
Pontiacpurebrred is offline
post #4 of 11 (permalink) Old 08-30-2011, 04:41 PM Thread Starter
Jim
Jim's Avatar
All good questions: Timing is right on, carb, gas, hoses, shroud, etc all in good shape. Fan is about 2 to 3 inches from radiator (If I remember correctly). Water Pump plate is in good shape and set a very minimal distance from the impeller (Whatever was recommended in a previous thread)
I guess I just got a POS..................
Still love my Goat, even if she is a little cranky every now and then. At least I can say shes HOT..................
Jim is offline
post #5 of 11 (permalink) Old 08-30-2011, 05:43 PM
need to flush the block chemically and be sure hoses are not collapsed inside.
pontiac is offline
post #6 of 11 (permalink) Old 08-30-2011, 06:56 PM
billcocarb's Avatar
Also had problems, did solid fan with spacer, shroud, water pump mod, timing correct and all the stuff in other forums. Finally, tried 1 gal anti freeze, for lubrication and anti rust, and 3 1/2 gal distilled water. Took her down 25 degrees. I know I have to change for cooler weather , but for now it's doing the trick.
billcocarb is offline
post #7 of 11 (permalink) Old 08-30-2011, 07:09 PM
Measure your water pump pulley......try a 6.5 inch one, if all other things above are correct. This has worked for a lot of Pontiacs. E
Eric Animal is offline
post #8 of 11 (permalink) Old 10-06-2011, 05:06 PM
I may be chiming in late but I will ask anyway. Are you saying you run straight water? Doesn't anti freeze raise boil over temp? 50/50 raises it to over 220 closer to 230*f. I live in canada so we are antifreeze year round. I may be wrong but I'm canadian so chances are slim lol.
Willshire is offline
post #9 of 11 (permalink) Old 10-06-2011, 06:34 PM
post #10 of 11 (permalink) Old 10-06-2011, 09:57 PM
646904GTO's Avatar
Another thing you might try is adding baffles to the top tank radiator making it a 3 pass unit. One on the top 1/3 of the way from the hose connection and one on the bottom 1/3 of the way from the hose connection. Worked for me.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
GTO Owner Age Range? powerman_dsr Member Introductions 1378 08-20-2019 01:18 PM
Age of GTO owner's 05GTO GTOforum Polls 156 04-26-2012 07:16 AM
Boyd Coddington dies at age 63 Tri-Power The Lounge 8 03-06-2008 12:29 AM
Edit: Age Poll of GTO Owners NJG8GT 2004-2006 GTO General Discussion 2 12-23-2007 10:03 AM
Average age of new GTO owners. Old_Goat 2004-2006 GTO General Discussion 25 10-11-2005 04:50 PM
