Is it is, or is it ain't a 65 goat? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-10-2014, 09:48 AM Thread Starter
Quoted: 9 Post(s)
There is a listing for sale on another website of a proposed PHS documented 1965 GTO. There is a photo of the firewall data plate. My humble understanding is that the number and letter "5N" designating the GTO option would be on the "ACC" line. The plate in the listing only shows 5 numbers in succession and no letters. How does one reconcile the lack of a 5N and supposed PHS documentation? Did a different plant stamp something else in lieu of the 5N, or may this be a suspect listing?
wishihaditback is offline
post #2 of 4 (permalink) Old 07-10-2014, 10:05 AM
The 5N was only used to identify the GTO option at the Kansas City and Pontiac plants, Baltimore and Fremont used a different coding systems. From the PHS docs verify the car has the options and engine codes as listed on the PHS and make sure the date codes proceed the data plate build date. Also verify the vin number matches your car and the tags have not been tampered with.
05GTO is offline
post #3 of 4 (permalink) Old 07-10-2014, 10:49 AM Thread Starter
Quoted: 9 Post(s)
Thank you for the clarification. I'll re-check the plate for the plant location and go from there.
post #4 of 4 (permalink) Old 07-11-2014, 04:20 PM
jmt455's Avatar
This isn't an answer to your question, but I believe it IS pertinent to the issue.
I strongly suggest you get your own copy of the PHS documents for any early GTO.
There are phony/modified PHS sheets out there.
I'd spend the $$ to get the documents directly from PHS.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
Gto ain't turning on Eddie05 Interior Discussions 2 03-14-2011 10:16 AM
Gto ain't turning on Eddie05 Service, Maintenance and Technical Discussion 0 03-12-2011 04:28 PM
06 modded Goat vs. 04 stock Goat vs. Nissan 240 SX turbocharged dustyminpin Racing and Kill Forum 16 11-09-2009 10:16 AM
Jiffy ain't Luben' PEARL JAM The Lounge 6 08-09-2007 08:09 PM
Ain't Gonna Buy No POS Furrin Veehickles Wing_Nut The Lounge 18 04-06-2007 05:28 PM
