air cleaner - Pontiac GTO Forum
post #1 of 11 (permalink) Old 10-27-2011, 05:02 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
air cleaner
Howdy gang!
I just got in my shiny new opgi after market air cleaner.
On initial install the whole assembly was moving a tad as I floored the accelerator pedal.
Adding a second gasket to the top of the carb. solved that problem (for now).
A part of the throttle linkage at the top of the carb actually put a small dent in the bottom of the cleaner.
I realize I can add another gasket as a shim , but I'm wondering what these "indents" in the bottom are for?
thanks as always
ps vegas was gruelling..............Hi Uncles E and Gee
ID:	12697   Click image for larger version
Topkat is offline
post #2 of 11 (permalink) Old 10-27-2011, 06:19 PM
Hi TK!,....you forgot the pic of the indents. E
Eric Animal is offline
post #3 of 11 (permalink) Old 10-28-2011, 05:54 PM
indents are to clear obstructions with linkages, dist, etc. Why did you get the one with the deep dish instead of the more common flatter one?
pontiac is offline
post #4 of 11 (permalink) Old 10-28-2011, 06:47 PM
Quoted: 99 Post(s)
The deep dish is what's causing the clearance problem.......
post #5 of 11 (permalink) Old 10-28-2011, 08:06 PM
TK !...either add more gasket thickness, get a different base, or alter the carb linkage!!!!! before something bad happens (LIKE YOUR THROTTLE STICKS OPEN!!) Safety issue...UE
post #6 of 11 (permalink) Old 10-29-2011, 06:31 AM Thread Starter
Topkat's Avatar
the only thing hitting as far as I can see is the ,whatever it is pump on the top drivers side of the carb. adding a 2nd gasket solved it but in going to "beat on it a tad" with a small ball pean and remove the 2nd gasket.
Topkat is offline
post #7 of 11 (permalink) Old 10-29-2011, 09:37 AM
Ok, just be careful...the extra gaskets won't hurt anything. The "pump" you are talking about is probably the accelerator pump.....E
post #8 of 11 (permalink) Old 10-29-2011, 04:13 PM Thread Starter
Topkat's Avatar
It was slightly hitting in 2 places, one on a vertical rod near the front d. side one on the p. side rear linkage.
My wife, who is in her own way a genius came out and put some very small dabs of PEANUT BUTTER on the offending pieces. It was thena simple matter of persuasion with a small ball pean.........nothing even close now!!!!!
something to be said for innovation!
Topkat is offline
post #9 of 11 (permalink) Old 10-29-2011, 08:13 PM
Now you just gotta keep the mice from eating the peanut butter under the hood!....Mrs. Kat is a smart lady!!
post #10 of 11 (permalink) Old 10-30-2011, 06:39 AM Thread Starter
Topkat's Avatar
too funny
ironic tho that you would mention that U E..........
Ive been informed we are off to see " Puss in boots" today
Topkat is offline
air cleaner and A.I.R. Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 02-19-2011 05:39 PM
Air cleaner SIXT5GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 11-09-2010 11:03 AM
Air Cleaner ID Frank Rossi 1964-1974 Tempest, Lemans & GTO General Discussion 4 01-23-2009 09:06 AM
65 GTO Air Cleaner fst65gto 1964-1974 Tempest, Lemans & GTO General Discussion 0 05-16-2005 05:32 PM
