Air cleaner - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-03-2014, 07:41 AM Thread Starter
69GTOCONVLOVER's Avatar
Air cleaner
Dumb question here. From the air cleaner a hose goes into the hole on the valve cover, do i need to have one connected, two, or both closed, or can i add two k&n oil filters on both sides?
Thanks...
69GTOCONVLOVER is offline
post #2 of 8 (permalink) Old 01-03-2014, 08:36 AM
Yes, that is a crank case vent tube. Installed correctly, it would run to your air cleaner and through a fiber filter. Matt
Matthew is offline
post #3 of 8 (permalink) Old 01-03-2014, 09:35 AM
Quoted: 100 Post(s)
In Costa Rica, probably legal to run open breathers on the valve covers. Factory was as Matthew mentioned, but vented will run the same. Just don't close them both up. Normally, one valve cover is closed and the other has a vent. That's plenty.
post #4 of 8 (permalink) Old 01-03-2014, 06:54 PM Thread Starter
Thanks for the replies.
What is the safest, cleanest, for least chance of problems?
post #5 of 8 (permalink) Old 01-04-2014, 08:25 AM
Original set up would be the best in my opinion, if you have the parts. Right side valve cover with vent tube hole, vent tube, air cleaner assembly and crank case vent filter. Matt
Matthew is offline
post #6 of 8 (permalink) Old 01-04-2014, 05:09 PM Thread Starter
Wow guys, apparently the tubing etc. From the air cleaner to the valve cover is missing. Glad it is in my garage now and no one else can touch it anymore. Can anyone please give me a link or a list of the parts that I'll need like the grommet etc.? Dammit
post #7 of 8 (permalink) Old 01-05-2014, 06:55 AM
Sure. Look at the Ames Performance catalog. Parts you need to make this work are:
Valve Cover Grommet (N220A)
Vent Pipe (N178)
Crankcase Vent Filter (N212CK)
Crankcase Vent Filter Clip (N212CL)
Vent Pipe Filter Hose (N178F)
Matthew is offline
post #8 of 8 (permalink) Old 01-05-2014, 07:55 AM Thread Starter
Thanks Matthew! You helped me out so much, appreciate it!
Martin.
air cleaner Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 10 10-30-2011 07:01 AM
Air Cleaner ID 67158 1964-1974 Tempest, Lemans & GTO General Discussion 13 09-18-2011 03:36 PM
air cleaner and A.I.R. Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 02-19-2011 05:39 PM
Air cleaner SIXT5GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 11-09-2010 11:03 AM
Air Cleaner ID Frank Rossi 1964-1974 Tempest, Lemans & GTO General Discussion 4 01-23-2009 09:06 AM
