Air Compressor Couplings **Help** - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-19-2012, 04:03 PM Thread Starter
Josh.AZ.GTO's Avatar
I have a new set of Hi-Flo air compressor male and female 1/4" pneumatic couplings. This past weekend I finally got my air compressor wired and everything connected. I have a Flexzilla hose. This is my concern....
I do not have the hard line completed yet, so I just have the hose connected directly up to the air compressor (out the side) with a shut off valve and a 3/8 reduced down to 1/4 npt for the male connector. On the hose I have a female 1/4 npt at each end. I have just been using straight air to blow dust around the garage. When the air compressor shut off valve is opened and air is in the line the female coupler leaks air. It hisses. I know its not on the compressor end, but I went to Home Depot and bought Husky 1/4" npt regular standard connectors and I am getting the same thing. I thought it might be the hose but I'm just at a lose to what is occuring. I've tried changing the female ends three times and its the same result at the compressor.
I can't imagine this is normal, but I could be wrong? Any suggestions or similar experiences. I have been reading here online about a few possible fixes but I thought I'd also try here. All my pneumatic couplings are all brand new.
JOSHUA
1970 GTO 455HO Cardinal Red
Josh.AZ.GTO is offline
post #2 of 4 (permalink) Old 05-20-2012, 07:55 AM
Just to make sure I've got this right in my mind.... you have a female quick-disconnect fitting on both ends of the hose and a male end on the compressor - correct?
Take a close look at your male disconnect fitting(s). Not all are created equal. They vary in the "width" of the wide part of the fitting - the part that the female fitting grabs onto and holds. Some of them are pretty narrow at the point of the "V" around this bead, others have a wider "band" of metal at this point. If the male fitting isn't the correct one for the female, especially if you use a narrow coupler with a female end that wants a 'wide' one, it will leak as you're describing.
(I'm SO tempted to say something here like "size matters" ---- but I won't.... )
post #3 of 4 (permalink) Old 05-20-2012, 12:49 PM Thread Starter
Thank you for the response Bear. I switched a few more out and seemed to find some with a better fitting. On the female end I stuck a flat head screw driver and compressed the center releasing the air, then plugged it back in. Seemed to work for now.
JOSHUA
post #4 of 4 (permalink) Old 05-22-2012, 02:39 PM
Quoted: 100 Post(s)
...........you just did, Bear..........but nobody is offended.
Air Compressor 67chivo 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 07-10-2011 02:53 AM
My new ac compressor came in, now what? gtogooch Service, Maintenance and Technical Discussion 17 06-05-2010 11:48 PM
Help with AC Compressor express705 1964-1974 Tempest, Lemans & GTO General Discussion 11 05-13-2010 03:58 PM
Driveshaft Couplings KyleGT05usmc Drive train, suspension, alignment and brakes. 10 03-19-2010 10:24 AM
A/C Compressor off at what RPM ? westell Service, Maintenance and Technical Discussion 2 10-19-2004 02:14 PM
