Air conditioning radiator rubber seals - Pontiac GTO Forum
post #1 of 17 (permalink) Old 07-17-2015, 12:53 PM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
Bought a seal kit from Ames with fasteners... thought I had all the parts to install... I've found that I really only have the bottom metal pieces and not the side ones..... Any one out there have any ideas on where to finds these items..
gtoearl is offline
post #2 of 17 (permalink) Old 07-22-2015, 07:07 PM
67Twistytee's Avatar
They're not reproduced as far as I know. I have a set of originals and used them as templates for new rubber seals. I think I've seen the rubber pieces in kits from OPG. Does anyone in your local club or nearby have ones you can use as a guide to fabricate your own brackets?
Andy
'67 GTO/Signet Gold over Parchment/Pontiac Built
67Twistytee is offline
post #3 of 17 (permalink) Old 07-23-2015, 08:51 PM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
Thanks very much for your response. As I said I purchased the rubber seal kit from Ames. And I looked into installing them it appears that I'm missing some of the metal pieces that attach to the rubber pieces. I don't belong to any clubs so I really don't have any resources to ask that question .. Perhaps that's something I should research. Thanks again for your help.
gtoearl is offline
post #4 of 17 (permalink) Old 07-24-2015, 07:12 AM
This probably doesn't help you too much without being able to see them in person, but the metal brackets are simple pressed steel with the rubber seals stapled to them. They wouldn't be too difficult to bend into shape if you had guide to go off. Attached is a blow-up from one of the seal kits. The sharpest angles are the ones listed as #4 & #5. You can probably gin something up with a little trial and error. I don't have ready access to my car at the moment or I would try to post a close-up photo. Maybe someone else who sees this can provide better detail. Good luck.
Name:	HPIM4740a gto ac seals.jpg
Andy
post #5 of 17 (permalink) Old 06-24-2019, 04:35 PM
Quoted: 11 Post(s)
Does anyone have templates that could be used to make up the metal attaching plates needed to install the seal kit?
Sixty7GTO is offline
post #6 of 17 (permalink) Old 07-01-2019, 04:06 AM
hilton8r's Avatar
Did you buy the same fastener kit (See below) ?
I bought the P168 A/C seal kit ($39) & the P168DK A/C seal fastener kit ($73) from Ames. I only worked on the baffles to the left & right of the radiator today. If I remember correctly, that's #10 & #11 in the picture 67Twistytee posted. I'll get to the rest of the baffles in a week or two.
That's a lot of money to spend for what I got. I'm wondering if the fasteners I got are defective (the one he's pointing to at the top right of the picture). When I pressed them in, one of the legs snapped off of three of them, and I don't think the legs should be mated together the way they are. Unfortunately, I don't have any baffles on the car to use as a guide, but one of the original clips was still in one of the holes.The quality does not appear to be there when comparing the two. And the ones that didn't break are very loose. It seems like the two legs need to be spread apart a bit to create any tension. Sorry, not sure how else to word that, and I'm too tired to care!
I'll reply back if anything new comes up in my case. Worse case, I'll use a small bolt, washer, and nut to hold them in place until I figure out something better. These aren't going to cut it.
John
hilton8r is offline
post #7 of 17 (permalink) Old 07-01-2019, 11:54 AM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
I believe I did buy those seal kits. It’s been many years ago when I bought it. I put some of them on where I could. Particularly the ones on either side of the radiator to go up and down the side. And the one that goes directly under the radiator the long pieces on each side of the radiator bottom side. I haven’t looked at the seal kit in a while to see what’s left but if I remember right I just didn’t have Metal pieces to help me attach the rest of it. You mentioned some pictures and I don’t see them. If someone could give me some close-up pictures of a completed seal kit installed that would be very helpful. And possibly I can fabricate some metal pieces out of some sheet metal. Thanks for any help. As mentioned the seal kit isn’t cheap and it’s a shame to have it sit on the shelf. Thanks
gtoearl is offline
post #8 of 17 (permalink) Old 07-01-2019, 05:54 PM
joelau27's Avatar
Quoted: 8 Post(s)
Call Ames, and talk to someone over there. They are quite knowledgeable, and can lead you in the right direction for solving your problem.
joelau27 is offline
post #9 of 17 (permalink) Old 07-01-2019, 06:47 PM Thread Starter
gtoearl's Avatar
Quoted: 22 Post(s)
radiator caps
May sound like a silly question but I think I need a new radiator cap. Which one should I choose? All the ones I’m looking at show a 16 pound cap for My 66 GTO. I believe the maximum stock AC Was 15 pounds. Any suggestions appreciated.
gtoearl is offline
post #10 of 17 (permalink) Old 07-02-2019, 03:53 PM
hilton8r's Avatar
I just got off the phone with Ames, and logged in here to give an update. I was told they have some notes for those fasteners.
The legs stick together when they are painted, and should be separated slightly before install. Also, you need to be dead on straight when pressing them in. The fasteners can be ordered individually (P168DC).
I ordered the wrong radiator insulators, so waiting on the new ones to arrive. Will replace the atf fluid in the meanwhile. I'll be able to try to start her up before too long!
John
hilton8r is offline
rubber for radiator support? virginiavenom 1964-1974 Tempest, Lemans & GTO General Discussion 7 07-22-2011 09:20 AM
Aftermarket Air Conditioning on a '66 hookemdevils22 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 38 05-15-2010 09:48 PM
AC radiator seals blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-10-2008 02:11 PM
air conditioning 75coug 2004-2006 GTO General Discussion 19 05-24-2005 09:52 AM
