Alternator and voltage regulator - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-08-2013, 12:25 PM Thread Starter
A million years ago when I worked as a mechanic I remember welcoming the technology of the alternator partly because it eliminated the need for a regulator. I'm putting together a 69 gto that someone else took apart and find a regulator among the parts. I look in the manual and sure enough the schema has3 wires from the harness going to a regulator. Is there an easy way to just get a more modern alternator and eliminate the regulator?
funbooker is offline
post #2 of 3 (permalink) Old 06-08-2013, 12:31 PM
NAPA sells a 1 wire alt that's pretty cheap too, but then your battery light will not work right.
post #3 of 3 (permalink) Old 06-08-2013, 07:09 PM
Yes.
And if you make other upgrades, like electric cooling fans, killer stereo, etc. you'll also find that the stock alternator can't keep up with the load.
I converted my 69 to a CS-130 format alternator spec'ed for an 80's Pontiac Safari wagon. It makes 105 amps as opposed to the original's 65. Eliminating the external regulator and running that alternator (or one similar) is simple, and I even kept my GEN light function.
1970 GTO voltage regulator sweet70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 01-30-2012 08:23 AM
voltage regulator Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 12-04-2010 04:43 PM
65 voltage regulator capacitor olde-goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 07-15-2010 08:57 PM
voltage regulator wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-13-2006 11:49 AM
