Another Axle Code Question - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-03-2015, 05:50 PM Thread Starter
zrsteve's Avatar
Quoted: 6 Post(s)
I was told when I bought my "65" with a 4 speed transmission that it has 3.55 gears on a Posi. After wire wheeling the right axle tube I cannot find any code, I've gone from the differential to the shock mount and have not been able to find any factory stamps. Ideas?
Also, on the differential itself there are the these numbers cast into the differential itself:
Left Side
CFD
2
Right Side
336 (or 8)
9788202
Thoughts?
Steve
zrsteve is offline
post #2 of 5 (permalink) Old 08-04-2015, 01:08 PM
Believe you have misread the casting number. it's fairly easy to do, 8's, 9's, 3's all look fairly close when degraded from rust, poor casting transfer, or globs of paint, the worst is powdercoat.
9799202 is a later Pontiac 8.2 10 bolt out of a '70-72 Pontiac Abody. As a mid '66 and later Pontiac 8.2 10 bolt, it is 1/2" wider on each side than the original '65 Pontiac 8.2 10 bolt which would have casting number 9779822. The "202" is a better rear, nodular casting, and will have tapered bearing axles.
post #3 of 5 (permalink) Old 08-05-2015, 09:58 AM Thread Starter
zrsteve's Avatar
Quoted: 6 Post(s)
You are correct, I did misread the casting number. I re-checked this AM and the number is 9799202.
As this is a later Pontiac 8.2 10 bolt out of a '70-72 Pontiac A-body, any idea where I can look for the axle code?
zrsteve is offline
post #4 of 5 (permalink) Old 08-06-2015, 02:22 PM
On the code location, believe front of pass side axle tube. Will go out and double ck on some '71 & 72 partscar roller rearends, I haven't cleaned or gone through a '70-72 Pontiac 8.2 rear in quite a while, instead build the 8.5's.
post #5 of 5 (permalink) Old 09-14-2015, 06:50 PM Thread Starter
zrsteve's Avatar
Quoted: 6 Post(s)
Found it on the left side. 021 HX.
zrsteve is offline
1965 Rear axle question 19GTO65 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 10 01-17-2016 02:41 PM
1967 Rear Axle Question GTO4UNME 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 09-28-2014 08:49 PM
65 GTO axle stand question Jamie65gto 1964-1974 Tempest, Lemans & GTO General Discussion 6 12-07-2013 04:07 PM
Rear axle question 68GTO4004Spd 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 5 06-27-2011 07:02 PM
1968 rear axle question JS_Bethlehem 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 4 12-03-2005 08:31 PM
