Another tire size question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-11-2014, 03:07 PM Thread Starter
I need to replace the tires on the rear of my 67 GTO convertible pretty soon. I'm thinking of going from my 235 60 15s to 255 65 15s for a couple of reasons. It will fix my speedo, lower the revs while cruising, and give a little more traction I assume. I have 15x7 Rally 2 wheels and the current tires fit fine with no rubbing. I do have new springs and drag bags installed so will the 255s fit?
WhittP is offline
post #2 of 3 (permalink) Old 12-11-2014, 03:39 PM
The new tires should check in at 28" total height and 10" wide if I calculate right.
What you have now are 9.25" wide and 25.1" high. I'd check with 3" block of wood and that should show you your new clearance. Width should be fine I would think as you are only adding less than 1/2 an inch to each side. But check anyway!
Someone else check these numbers.
BierManVA is offline
post #3 of 3 (permalink) Old 12-11-2014, 08:50 PM
I'll assume that you are looking at 255/60/15 and not 255/65/15, which I have never seen before. I have the 255/60/15 BFG Radial T/As on Torq Thrust II wheels with 4.5" backspacing and they are a tight fit but look awesome on my car. This tire is 27.05" tall and I did roll the fender wells slightly to give additional clearance but don't think it was required. I have the drag bags as well, but don't run much more than 10 lbs in them.
I'm not far from you and you are welcome to come by and test fit one on your car if you like, PM me with your number if you want to do it.
Regards,
randy1966GTO is offline
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 10:35 PM
TIre size question 235-55-17 danfigg 2004-2006 GTO General Discussion 2 06-19-2011 12:26 AM
tire size Pontiac Tempest Cstm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 01-02-2009 07:28 AM
Tire size question GTO_Addict Wheels and tires 3 06-10-2008 11:04 AM
Stock 17" rim tire size question zomowiec Wheels and tires 0 02-23-2008 10:17 AM
