Any advise on Points? - Pontiac GTO Forum
post #1 of 11 (permalink) Old 04-25-2008, 07:07 PM Thread Starter
If you can help it would be great. Im sure mine are due.
POOF is offline
post #2 of 11 (permalink) Old 04-25-2008, 08:39 PM
Do a forums search for "MSD" and install one. Your points will last forever and your ignition will thank you for it with quicker starts, increased performance and gas millage.
post #3 of 11 (permalink) Old 04-25-2008, 08:53 PM
I did away with the points and condenser in both of mine and replaced them with the Crane Cams XR-I.
A few advantages are;
*) built in rev limiter
*) no ballast resistance needed
*) no gap adjustments
*) no problems with dwell settings
05GTO is offline
post #4 of 11 (permalink) Old 04-29-2008, 07:46 PM
VettenGoat's Avatar
I've always been partial to Accels. Get the 42 oz points though and they'll run strong through 5500 RPM (probably more, but that all I ever pushed them). Most standard points are 32 oz and crap out after 4 grand. Get a little tube of cam lube and put a light coating on the distributor lobes too.
Mike
VettenGoat is offline
post #5 of 11 (permalink) Old 04-30-2008, 10:16 AM
5500RPMs !! You will float the crank never mind the points!!! Eric
Eric Animal is offline
post #6 of 11 (permalink) Old 04-30-2008, 10:42 AM
Actually it`s the valve springs that "float" and limit RPMs at the top.
post #7 of 11 (permalink) Old 05-01-2008, 05:22 PM Thread Starter
Ok, here's another Question. Can any one tell me the Dwell for an 6.6L no Ram Air?
POOF is offline
post #8 of 11 (permalink) Old 05-03-2008, 08:20 AM
70gto's Avatar
I love my points never had a problem with them, I use 30 degrees and that is per book for dwell. about .016 point gap. how many miles a year do you drive it? Stick with Blue Streak brand i believe they are still american made.
Not bad for $400, it was Palladium Silver, Primer, and very tired. www.benchmarkonline.biz Trans shop owner
70gto is offline
post #9 of 11 (permalink) Old 05-03-2008, 11:46 AM
The dwell should be 30 degrees. Rukee, thanks for the valve thing!
post #10 of 11 (permalink) Old 05-03-2008, 05:31 PM Thread Starter
Thanks for all the Help! I looked for Blue Streak but didn't find them so... I bought Borg Warner.
I just want to thank all you guys for answering all these dumb questions.
POOF is offline
Need Some Advise warmongoose66 2004-2006 GTO General Discussion 58 02-03-2008 12:59 AM
Newbie Here and need some advise Richdawg192 Intake and Exhaust Discussions 6 02-02-2008 10:58 PM
Stock Shift Points A4 AndrewZPSU Service, Maintenance and Technical Discussion 5 06-23-2006 01:43 PM
Questions about shift points RookWV Racing and Kill Forum 5 05-26-2005 07:37 PM
Jacking Points -Revealed!! diverdan Service, Maintenance and Technical Discussion 8 05-20-2005 09:23 AM
