Anyone have safety harnesses? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 05-06-2011, 08:02 AM Thread Starter
I have a bench seat but I'd like to install some safety harnesses instead of just lap belts. Every once in awhile i want to take curves and do other things (unmentionables) and the lap belts just don't cut it. Also, my passengers get scared a little since they've never not had the shoulder straps. I think I could use a 4-point safety harness. I belive all of my eye bolts will work out, I'll just have to make a few adjustments until they fit around the seats right. I don't think I could use a 5 or 6 point. So has anyone ever installed any before or know of any good 4 points? I don't need the best and cam locks and such, just more support. Thanks.
- Judson
Pontiac Z is offline
post #2 of 12 (permalink) Old 05-06-2011, 09:44 AM
I have a bench seat and five point harness. The shoulder belts mount to the roll bar on mine and I don't really use the submarine belt, although I've considered having an upholstry shop put a slot in the lower cushion for it. I don't race actively on a sactioned track in competion so it's not really necassary.
The belts I use are RCI. Be aware that most NHRA santioned tracks require replacement or recertification of harnesses every 2 years.
post #3 of 12 (permalink) Old 05-06-2011, 12:35 PM Thread Starter
I don't have a rollbar or anything. almost stock interior. Do you think the four point could bolt to the eye bolts on the side and the middle of the seat for the lower ones and then the eye bolts on the floor for the upper bolts?
post #4 of 12 (permalink) Old 05-06-2011, 01:11 PM
You can anchor them to the floor but I would do some serious reenforcement to wherever you attach the shoulder harness and use the stock mounting points for the lap belts.
They do offer floor mount or rollbar mount.
post #5 of 12 (permalink) Old 05-09-2011, 07:24 AM Thread Starter
will the stock eye bolts break from being pulled on too hard by the straps?
post #6 of 12 (permalink) Old 05-09-2011, 07:42 AM
Stock does'nt use "eye bolts". Post a picture of what you intend to use. I would use only grade 8 hardware.
post #7 of 12 (permalink) Old 05-09-2011, 07:52 AM Thread Starter
alright. I'm at school but I'll get them up later this evening
post #8 of 12 (permalink) Old 05-09-2011, 08:36 AM
jetstang's Avatar
Do not run the shoulder harnesses from the floor and over the top of the seat. In a wreck when you go forward the harnesses will pull down on your shoulders and compress your spine and cause more damage then not having them at all. Either mount the shoulder harnesses off of a roll cage, or just see if you can get a stock 3 point harness, if you have the upper shoulder bolt mount.
Burning rubber since 1982!!
jetstang is offline
post #9 of 12 (permalink) Old 05-09-2011, 09:04 AM
^^ Ouch!
post #10 of 12 (permalink) Old 05-09-2011, 01:15 PM
Indecision's Avatar
Do they make regular harness bars for these cars without having an actual cage? I've never looked into it, but it could be an option. I agree not to run them to the floor because of the aforementioned possible problems. I've also read several different opinions saying that with a 4pt, submarining is a really big issue to consider whether you race or not. Accidents happen on the street too. There's a lot of info on it if you search. I have never used a 4pt myself, just either factory or 5pts, so I can't personally speak on the matter.
1966 GTO 428ci/4spd - spun bearing
Indecision is offline
Safety Mode GTOWS6GUY Service, Maintenance and Technical Discussion 4 03-24-2008 03:04 PM
Safety Hayes21890 2004-2006 GTO General Discussion 3 06-20-2007 12:18 PM
safety mode Sporaclic 2004-2006 GTO General Discussion 19 05-13-2006 03:08 PM
safety? larry 2004-2006 GTO General Discussion 2 04-08-2005 11:34 PM
Safety madx2 2004-2006 GTO General Discussion 1 12-29-2004 04:56 PM
