Anyone running Torker II Intake? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-16-2014, 08:58 AM Thread Starter
EdR
Hey guys.. I have a 69 GTO with a 400. Having my "62" heads highly ported. I'm thinking to take full advantage of the porting I'm going to need to be able to handle more volume than a Performer RPM, but have been reading some pretty mixed reviews about the Torker II. Bad reviews tend to come with folks with 350s that are basically stock. Kind of a no brainer that a Torker II isn't going to work in that case, but with a 400, moderate cam, highly ported heads, hooker pro comp headers, seems like Torker II would be more balanced to the rest of what I have. Of course output is important but I also want to be able to drive the thing around town. Anyone have experience with Torker IIs on modified 400s?
EdR is offline
post #2 of 4 (permalink) Old 12-16-2014, 09:19 AM
chuckha62's Avatar
Quoted: 18 Post(s)
As you mentioned, in a street application, the Torker II is the wrong manifold. Since the stock 400 runs out of steam over 5500 RPM and develops torque down low, the Torker was crippling my stock '67 400. I went back to the stock cast iron manifold and got all my low end torque back. If you're going to be routinely launching at over 3000 RPM, the Torker II should see an advantage.
chuckha62 is offline
post #3 of 4 (permalink) Old 12-16-2014, 12:56 PM
The torker 2 is for a big cammed low geared beast that needs 3,000pm before she comes to life. I had one in my monte, and although it was ok, it is not for a stock application.
Nightshade 68 HO is offline
post #4 of 4 (permalink) Old 12-16-2014, 06:18 PM
Quoted: 102 Post(s)
The best 4bbl intake for an engine less than about 650HP is the factory stock Q-jet intake with, you guessed it, a Quadrajet carb sitting on top of it.
Edelbrock Torker and carb power gains SPCMarty 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 34 09-23-2011 01:18 AM
just got my 04 running GMforlife Member Introductions 3 05-19-2011 05:38 PM
Not running right need help taylorb765 2004-2006 GTO General Discussion 3 06-12-2010 01:50 PM
RE: Anyone Running E3's? PDQ GTO Engine Discussions 2 06-29-2008 07:58 PM
water pump bolt running throug intake manifold wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-02-2006 09:35 PM
