Backfiring - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-26-2011, 11:35 PM Thread Starter
Backfiring
Hey guys, my 68 gto 400, 4 speed, has began backfiring when I put my foot into it. It is backfiring right underneath me, not at the end of the exhaust. I checked the timing and it is good (14 advance at idle) that is where I have always ran it. It also began surging when coming to a stop. Are these problems related? they both began around the same day. Thanks
simmons68 is offline
post #2 of 7 (permalink) Old 08-27-2011, 06:52 AM
Idle mixture screws not properly set.
Spark plug issue not firing correct
Spark plug wire issue
Sounds to me like a carb issue.
When was the last time the carb was cleaned, or worked on?
post #3 of 7 (permalink) Old 08-27-2011, 11:29 AM
69Goatee's Avatar
Is it only on driver side? You could have a dead cylinder, ignition related. The fuel/air mixture igniting in the header/manifold. Get an infra-red temp gun(very useful), and check the temp at every exhaust port after running the engine for a while. If you have a dead cylinder, it be cooler than the rest. Then check the plug and wire on that cylinder, or cap and rotor.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #4 of 7 (permalink) Old 08-27-2011, 11:30 AM Thread Starter
backfiring
Carb is two years old. Never had any trouble. Its an edelbrock 750. Is there a safe idle setting I can do? I'm not a carb guy. I think the book says 1 half turns from lightly seated. But I haven't tried it
post #5 of 7 (permalink) Old 08-27-2011, 12:34 PM
Check/change your spark plugs
Eric Animal is offline
post #6 of 7 (permalink) Old 08-27-2011, 03:28 PM
Quoted: 98 Post(s)
Sounds too lean to me. I'd check for vacuum leaks/carb mixture. Try this: at idle, take the air cleaner off and mist a small amount of carb cleaner into the carb. If it speeds up and smooths out, it's too lean----caused by a vacuum leak or the carb itself.
post #7 of 7 (permalink) Old 08-28-2011, 03:39 PM
Check it with the air cleaner off, it may be poping through the carb. If it does it consistantly through the carb under throttle, it could be a bad cam lobe.
