bappity bappity bappity - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-05-2011, 08:23 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
What are the "extra" 2 holes (in the lower front outside edges) of the timing chain cover for?
Also, what are the 2 holes in the front of both heads?
The non- threaded ones
thanks as always
(pours GTO guy another 1800 shot)
Topkat is offline
post #2 of 7 (permalink) Old 02-05-2011, 10:01 AM
The holes in the timing cover are "leftovers" from days past. The early V8 cars ('55-'59, anyway, maybe a bit later) use a "front mount" where the timing cover was used to support the front engine mount. I have a '57 347 here from a Starchief with the mount still attached. All the early stuff had a cast iron cover. They MAY have used the aluminum version in the '62-'66 GMCs, can't say for sure.
Which holes in the heads? You mean the 1 3/8" diameter? They're for expansion plugs, and the only "non-threaded" holes in any of the cores here now. If not, what casting number, and a more precise location on those holes?
Jim
Mr. P-Body is offline
post #3 of 7 (permalink) Old 02-05-2011, 12:12 PM Thread Starter
Topkat's Avatar
the ones to the outside
Topkat is offline
post #4 of 7 (permalink) Old 02-05-2011, 02:20 PM
Ah... those heads are 670's right? Those are the fittings where the A.I.R. (smog pump) connected, if the car originally had one. Looks like yours are open. You'll probably want to find some pipe plugs to seal those holes off on both ends of the heads, if they're open.
post #5 of 7 (permalink) Old 02-05-2011, 02:29 PM
Quoted: 118 Post(s)
Topkat, I'd say something, but it already got said! ..... Back to "Top Cat" and "Krazy Kat" uploads.....
post #6 of 7 (permalink) Old 02-05-2011, 03:09 PM Thread Starter
Topkat's Avatar
my car does have the AIR system , as it was made in CA, this being said, what goes in the holes?
ty
Topkat is offline
post #7 of 7 (permalink) Old 02-05-2011, 04:18 PM
Quoted: 118 Post(s)
There is a cast aluminum piece that bolts over the front of the head that has an outlet for the AIR pump hose. You may be able to find pics of one on line. My car is a Federal car, from Tennessee, so I can't show you a picture. If you don't have all the pieces, good luck. They are almost impossible to find, and command a premium price.
