battery cable tube - Pontiac GTO Forum
post #1 of 10 (permalink) Old 04-07-2011, 01:35 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
battery cable tube
I got my battery cable heat shield tube, the long one that is supposed to mount to the top of the drivers side motor mount.Which puts it right up against the ex manifold. Seems like it would be better being run along the inboard side of the motor mount.
Maybe somehow I could run it along the inboard side and use the motor mounts bolts to secure the tube to?
The installation instructions say there needs to be 2 holes drilled into the top of the mount to screw the tube to.
Mine of course has no such holes.
I have the engine compartment like 95% built and getting that mount out is virtually impossible.
Ideas?
thanks as always
ps I still kinda like my idea of the starter wires being run out the back toward the firewall and wrapping them in hi temp header wrap.
Topkat is offline
post #2 of 10 (permalink) Old 04-07-2011, 02:29 PM
My tube mounts on the second from the back bottom head bolt and routes the wires behind the exhaust manifold right to the top of the starter.
post #3 of 10 (permalink) Old 04-07-2011, 02:57 PM
he is talking about the HO tube, not the typical tube.
pontiac is offline
post #4 of 10 (permalink) Old 06-28-2011, 10:45 AM
relmers's Avatar
66 GTO battery cable tube
Did the 1966 GTO come with this tube?
relmers is offline
post #5 of 10 (permalink) Old 06-28-2011, 01:06 PM
yes.
post #6 of 10 (permalink) Old 06-28-2011, 02:22 PM
Quoted: 103 Post(s)
Two tubes, two different mounting locations. ONly '67 up with HO manifolds had the motor mount-mounted tube. All the standard non HO cars had the one as Rukee described. The HO spec tube will work with HO manifolds on earlier cars, as long as you have the HO engine harness and Battery cable. One reason I left the stock log manifolds on my '67 when I recently had the engine out....way too much hassle for me!!
post #7 of 10 (permalink) Old 06-28-2011, 08:31 PM
Top, You are right about the location. Your tube is supposed to be mounted on the bottom. Reread the directions again. Do not mount it on top
dimitri is offline
post #8 of 10 (permalink) Old 07-04-2011, 01:48 PM
relmers's Avatar
yes.
Any idea what length of battery cable would be required to go through the exhaust mounted tube?
relmers is offline
post #9 of 10 (permalink) Old 07-05-2011, 02:20 AM Thread Starter
Topkat's Avatar
It does go on the top. BARELY
and your right Gee, its a [email protected]#$%^&*()(*&^%$#@! hassle
Topkat is offline
post #10 of 10 (permalink) Old 07-07-2011, 04:14 PM
Quoted: 103 Post(s)
The "regular" cable length for non-HO cars is about 42". Just went thru this on mine....
Speedometer Cable? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-13-2010 11:07 AM
Battery Cable Ground injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-02-2010 08:54 AM
When your battery was dead, did your battery light stay on? SueY816 2004-2006 GTO General Discussion 7 05-31-2010 05:54 PM
Speedometer Cable ?? AGETECH 1964-1974 Tempest, Lemans & GTO General Discussion 8 11-08-2009 10:04 PM
