battery ground - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-22-2011, 01:51 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
battery ground
Where does my 67 Goat gets its battery ground?
How is it routed?
thanks as always
Topkat is offline
post #2 of 6 (permalink) Old 02-22-2011, 02:14 PM
the front cylinder head bolt should have a threaded stud on it for the ground cable. then there should be a braided copper wire from the frame to the inner fender on the right side to ground the body. that completes the ground circuit.
freethinker is offline
post #3 of 6 (permalink) Old 02-22-2011, 03:27 PM Thread Starter
Topkat's Avatar
There should be a jumper from the rear of the motor to the firewall to I believe
Topkat is offline
post #4 of 6 (permalink) Old 02-22-2011, 04:09 PM
Correct sir. There are two braided ground jumpers. One is from the rear of the cylinder head to the firewall, the other is from the inner fender to the frame.
post #5 of 6 (permalink) Old 02-23-2011, 03:51 PM
Quoted: 103 Post(s)
The cyl. head braided ground is near where the ign. coil mount is. The other is the passenger side inner fender (lower edge) to frame, as stated. Top, you need a factory manual!!
post #6 of 6 (permalink) Old 03-06-2011, 12:07 AM
don't forget on the battery ground to the stud, a star type washer that goes on the stud first, then the battery cable on top of it, then the nut.
pontiac is offline
Ground problem>>>>>??????? skuzzzusmcdevildog 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 01-27-2011 12:36 PM
Battery Cable Ground injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-02-2010 08:54 AM
When your battery was dead, did your battery light stay on? SueY816 2004-2006 GTO General Discussion 7 05-31-2010 05:54 PM
Ground Effects question CQQL_GTO 2004-2006 GTO General Discussion 19 03-03-2010 09:48 PM
