Battery Light Came On - Pontiac GTO Forum
post #1 of 6 (permalink) Old 08-26-2013, 08:00 AM Thread Starter
I finally got my 67 GTO running again after my new rally gauge installation and everything was working great until my drive to work this morning. About 10 minutes into the drive my battery light came on at idle. I had the headlights on but no other power accessories. I turned off the headlights since the sun was about to come up. Off idle the light went out and then came on again at the next stop lights. At the last stop there was actually a buzzing sound when the light came on. I assume this is the voltage regulator (which is a new unit from Perf Years)
I think I'll drive it to Autozone over lunch and have them test things but I wanted to get some opinions on here first.
WhittP is offline
post #2 of 6 (permalink) Old 08-26-2013, 11:53 AM
It is not uncommon to have a bad (out of the box) voltage regulator, I had the same problem when I restored the 66. The first 2 were bad and the 3rd worked.
If the alternator checks out at autozone I would replace the VR.
05GTO is offline
post #3 of 6 (permalink) Old 08-26-2013, 01:23 PM Thread Starter
Well the car wouldn't start at lunch time and I somehow forgot my cables. I pulled the battery out and a buddy gave my a ride to Autozone and had the battery checked. They had to charge it a bit to get a reading but it came back good. So now it's either the alternator or the voltage regulator. What's the best way to test this? I have a multimeter and a battery charger with an alternator test built in.
WhittP is offline
post #4 of 6 (permalink) Old 08-26-2013, 02:54 PM
Check that you have battery voltage at the big red wire at the back of the alt. You should have 14.2-14.6v running at the battery. If not remove the alt and have it tested, if it passes then more then likely your VR is bad, even though it's new.
post #5 of 6 (permalink) Old 08-26-2013, 02:58 PM
jmt455's Avatar
I had trouble getting a good voltage regulator for my 68.
They seem to be very easily fried!
Took 3 tries before I got a good one. I ended up with one of the solid state type. I was warned that they are not as durable as the old contact type regulators, but mine has been performing well for over a year.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #6 of 6 (permalink) Old 08-28-2013, 07:41 AM Thread Starter
I ended up putting a new voltage regulator and a new alternator on it before i could get a 14.4v reading at the battery. Everything seems good now and thanks for the advise.
WhittP is offline
1967 Battery Light purerum 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-04-2013 06:01 PM
Question about battery (idiot) light rwhitaker 1964-1974 Tempest, Lemans & GTO General Discussion 5 06-11-2012 01:25 PM
When your battery was dead, did your battery light stay on? SueY816 2004-2006 GTO General Discussion 7 05-31-2010 05:54 PM
Battery Light teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-26-2009 10:33 PM
Idiot light on after dead battery. vette68 Service, Maintenance and Technical Discussion 4 08-12-2006 07:08 PM
