Beautiful 1971 GTO. Need help with some history! - Pontiac GTO Forum
post #1 of 11 (permalink) Old 07-20-2014, 10:09 PM Thread Starter
Hello everyone.
I am new to the GTO world. I am proud to say I own a 1971 GTO 455. I bought the car claimed as a matching numbers car. So far everything is correct. I am tho curious where to find the motor stamp to verify the 455.
Little about this car from the information I have researched.
1971 GTO
455 with AC
Only upgrades is exhaust.
Car shows 89,000 miles
Auto transmission
62-62 paint code- Canyon Copper Metallic
Production date: 4th week of Dec. 1971
Built in Fremont CA.
Interior code- 263-Saddle
I am the 4th owner of this car. A gentle man from North Dakota had bought it from a gentleman in Arizona and this car has been parked inside under wrap for years. The shop he was renting in his town wouldn't allow him to re-new the contract because they wanted to build a gas station on the corner lot. So he had to sell some of his collection. This car was auctioned at a car auction and ended up in my garage in Sask. Canada. I have never seen a car so clean underneath and have zero rust at all! I replaced a few gaskets as they were dried out, timed and cleaned the carb. This car starts and runs great. I love it.
I am curious what you guys think of this find. I am new to GTO's but they have always been on my dream list.
ID:	42417   Click image for larger version
ID:	42425   Click image for larger version
ID:	42433   Click image for larger version
Jward430 is offline
post #2 of 11 (permalink) Old 07-21-2014, 08:32 AM
Roger that's Avatar
The 71 came with 2 455 options. An HO (high output) and a non HO. The HO code with an Auto trans (found on the front of the block on the passenger's side under the head) is YE. The non HO Auto trans code is YC. These codes could also be used on other engine displacements so you would need to look for another code in the rear of the engine on the passengers side below the head. The YC 455 code is 485428. The YE 455 code is 483677, my book says that code came on Judge's only. If you really do have matching numbers, the VIN number should be on the front of the block, passenger's side near the timing chain cover in a very fine font running vertically.
Roger that is offline
post #3 of 11 (permalink) Old 07-21-2014, 08:56 AM Thread Starter
Thanks for the quick reply! From the info I was given on the car its a suppose to be a original 455 non HO. Ill take a look tonight at the spots you mentioned to look at post my findings.
Jward430 is offline
post #4 of 11 (permalink) Old 07-22-2014, 08:31 AM
Gorgeous car!
post #5 of 11 (permalink) Old 07-22-2014, 09:07 AM
Originally Posted by BearGFR View Post
Gorgeous car!
Welcome to the forums!
post #6 of 11 (permalink) Old 07-22-2014, 09:56 AM Thread Starter
Hey guys quick question. First day driving was last night I have a slight lifter/valve tick. I pulled the covers off and no visual damage. Some guys mentioned I should try using marvel majiv mystery oil or XM5. Than change my oil with royal purple. If noise continues to than look deeper into pushrod, rockers etc. Curious on your guys thoughts?
It's not a loud loud ticking honestly it sounds like the classic ford Tryton motor tick but a shade quiter. It bugs me and It needs to be corrected.
I have ruled out a leaky manifold, faulty fuel pump, made sure rockers weren't hitting the covers etc.
This is a bone stock 455. Thanks guys.
Jward430 is offline
post #7 of 11 (permalink) Old 07-22-2014, 01:23 PM
Make sure you use an oil with high ZDDP content. ZDDP has been "disappearing" from oil since roller lifters became the norm in new cars.
post #8 of 11 (permalink) Old 07-22-2014, 06:36 PM
Quoted: 391 Post(s)
Keep in mind, 89,000 miles can be a lot of miles on that era car/engine. Might be time for new lifters. If original, I would definitely install a new timing chain and gears at that mileage, so if you do that, not much extra work to install new cam and lifters at the same time to freshen it up. Assuming it is not using any oil and needs an overhaul.
They make an engine/automotive stethoscope that may help you pinpoint the "tick". They sell for about $20.00. Could be a good tool for you to isolate the "tick" or tell you what it isn't -for piece of mind.
post #9 of 11 (permalink) Old 07-22-2014, 11:39 PM Thread Starter
I changed the oil today and put in some Royal Purple and it did quite down some, but I can still hear it especially after the motor is warm. I used a long screw driver this evening and it sounds a bit different and louder near the rear of the driver sides valve cover. I took the valve covers off last night but visually couldn't see any damage. Ill take them off tomorrow again and run the motor. (not sure why I didnt do that last night) Like PontiacJim mentioned it's probably about time for a refresh. I'd like to keep this motor stockish. I have a few questions for you guys.
What would you guys recommend for parts brand etc?
I looked a little online at parts but this will be my first time with valvetrain. Does anyone reputable put together a kit? (Cam,lifters,pushrods,valves, gaskets etc)
Input on a good set of gears and timing chain?
Jward430 is offline
post #10 of 11 (permalink) Old 07-23-2014, 05:57 AM
silversport's Avatar
nice car...thanks for sharing...
Bill
**QSM/RH/A4/17**1 of 52**
silversport is offline
Beautiful 1966 GTO Adam C 1964-1974 Tempest, Lemans & GTO General Discussion 3 08-29-2013 06:47 PM
Are there any beautiful Ladies that drive GTO's??? GOGOGTO The Lounge 23 01-07-2011 11:42 AM
cheap but beautiful rims for GTO enjracing Wheels and tires 9 08-06-2006 01:47 PM
