Best Fit Headers for 1969 GTO MT? - Pontiac GTO Forum
 2Likes
  • 2 Post By geeteeohguy
post #1 of 6 (permalink) Old 03-31-2016, 08:03 AM Thread Starter
EdR
Hi.. I need to buy a pair of headers for my 69 GTO manual transmission. I had a pair of Hooker Super Comps but I sold them because I had to literally remove the heads in order to get at the header bolts. I was thinking I would get a pair of Doug's headers because they seem to be easier to bolt on, but now I'm reading they interfere with clutch linkage and the reverse steering column lock linkage on 68 and 69 GTOs. Doesn't anyone make a pair of headers that will bolt on and not interfere with the linkage?
EdR is offline
post #2 of 6 (permalink) Old 04-08-2016, 02:27 PM
Quoted: 117 Post(s)
How about the Ram Air/HO cast manifolds? Direct bolt on, no leaks, no mods, and about 90% as effective as tube-type headers.....
1968gto421 and Goat Roper like this.
post #3 of 6 (permalink) Old 04-08-2016, 11:27 PM
devildawg's Avatar
I would have to agree with geeteeohguy and recommend the factory ram air/ho headers. I had nothing but clearance issues with the headers I put in my 326 Tempest between the starter,frame,steering coupling and the list goes on. In and out numerous times to get the clearance required via malitizeing and using a mini sledge pounding,hammering,cursing,slamming,banging more cursing,tweaking,pounding and on and on until they finally fit.I loved the sound (check out youtube /65 Tempest Restoration) for sound on throttle up but was not worth the hassle. I'm now converting to a 4 speed and now have issues with the z-bar clearance so they're coming out. I have the original manifolds and hope to achieve the same throaty tone with a more aggressive muffler.Seeing that your dealing with a GTO I would highly recommend you check out the factory headers at Ram Air Restoration. Maybe a bit more money but you'll be able to get that great header sound and save yourself a host of clearance and heat issues and keep your ride closer to factory original.
Best of luck and keep us posted
devildawg is offline
post #4 of 6 (permalink) Old 04-09-2016, 01:41 PM
rickm's Avatar
Quoted: 5 Post(s)
when buying headers, stay away from brands that list them as fitting a wide range of years n applications. the more specific to your car, the better the set will fit. hooker you just pay for the name brand.
rickm is offline
post #5 of 6 (permalink) Old 04-10-2016, 06:07 PM
Unless you're trying to get every last bit of power out of the engine, the HO manifolds are definitely the way to go --- I say this and I have Doug's headers on my car (69, automatic, round port heads). I've heard from other sources that Mad Dog Headers fit very well but I have no direct experience. Generally speaking, Headers are a pain -- all of them.
post #6 of 6 (permalink) Old 04-10-2016, 10:01 PM
maktope's Avatar
I have hooked headers and when I had the Manuel in I just had to run my linkage between the tubes. Really no problem at all.
maktope is offline
Classic auto air perfect fit system 1969 GTO joesweeting 1964-1974 Tempest, Lemans & GTO General Discussion 0 07-27-2014 04:49 PM
How do i make headers fit my 65 gto pontiacyellow 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 02-22-2013 04:06 PM
Will c6 kooks headers fit an 05 gto?? DelawareGTO Intake and Exhaust Discussions 6 12-03-2011 08:30 PM
Will 05-06 Headers fit an 04 GTO? gtogooch Intake and Exhaust Discussions 3 10-15-2010 11:39 PM
Will these headers fit ohnogto Service, Maintenance and Technical Discussion 5 07-29-2005 11:36 AM
