Best Place to buy a rebuilt Quadrajet? - Pontiac GTO Forum
post #1 of 17 (permalink) Old 10-15-2014, 08:10 AM Thread Starter
EdR
I have a Holley 650 on my 400 now that is to small given what I have done to the engine so I'm looking to get a rebuilt Quadrajet that is set up for my engine and drive train. Rather not go to the big national chains. Any suggestions?
EdR is offline
post #2 of 17 (permalink) Old 10-15-2014, 03:19 PM
68Resto-mod's Avatar
I think the reason no one has responded to your question very quickly is because they know you may not want to hear the answer.
Most of the regular guys on this forum will tell you that the best way to get a correctly built Q-jet is to send an old one to Cliff Ruggles of Cliff’s High Performance. He is the go-to Q-Jet guru. Only thing is, he has at least a one year waiting list for re-builds.
If you want to go this route, find a 1976 to 1978 vintage Q-Jet off of a large cubic inch GM motor. Note that Pontiac Q-Jets have the fuel inlet on the front of the carb as opposed to a side inlet on other GM applications. For my 68 400 project, I found a 77 vintage Q-Jet used on a corvette (no hate mail please). I had to modify the fuel line with flex hose for the fuel line. I had Cliff hand pick a rebuild kit to match my engine/drivetrain setup and did it myself after reading his book. Here is a link to his web site:
Cliffs High Performance Quadrajets :: Qjet Carburetor Rebuild Kits, Parts, Quadrajet Rebuilding, Quadrajet Parts, Bushing Kits, Carb Tuning
You could do the re-build yourself but you must read Cliff’s book “How to Rebuild and Modify Rochester Quadrajet Carburetors” and follow the procedure to the letter.
Good luck
68Resto-mod is offline
post #3 of 17 (permalink) Old 10-15-2014, 04:09 PM
wings012345's Avatar
wings012345 is offline
post #4 of 17 (permalink) Old 10-15-2014, 05:23 PM Thread Starter
EdR
Good luck
Thank you for the response. I had found Cliffs website before I posted here. I'm not patient enough to wait a year, and although I'm tempted to try a rebuild myself I don't want to add another variable to the mix. I'd always be second guessing if any issue I had was related to my rebuild. I'd rather just get a rebuilt carb from a reputable source that I can have a high degree of confidence in. I wish cliff was selling rebuilts. But thanks anyway.
EdR is offline
post #5 of 17 (permalink) Old 10-15-2014, 05:28 PM Thread Starter
EdR
Please do.. thank you. Are they customizing the carb to match your engine and drive train set up?
EdR is offline
post #6 of 17 (permalink) Old 10-15-2014, 10:45 PM
They make you select your model, year and engine before they get to your carb. The # on The Quad they said they were sending was a 702XXXX# which i believe what should be on a 68 gto 400. Of course its rebuilt with modern parts. But like you, place i called to rebuild the existing were taking to long. I use to get carbs from Pep Boys back in the day and they were fine. I'm sure this will be just fine
post #7 of 17 (permalink) Old 10-15-2014, 11:02 PM
jetstang's Avatar
Rebuilt Q jets are hit or miss, like rebuilding them, could be great or junk. Holley's and edelbrocks are just easier. Throw one on for the mean time, and have a q jet built. You will probably stick with the Holley in the end, I hate edelbrocks.
Burning rubber since 1982!!
jetstang is offline
post #8 of 17 (permalink) Old 10-16-2014, 06:41 AM
Originally Posted by jetstang View Post
I hate edelbrocks.
Why? Is it just a familiarity thing?
I've found Edelbrocks to be much easier to tune for a street car. Only owned one DP though.
ibarbuckle is offline
post #9 of 17 (permalink) Old 10-16-2014, 09:11 PM
Jared's Avatar
Quoted: 5 Post(s)
Edelbrock's are easy to tune. I had one on my 84 Camaro and it was great on the 305. I also have one on my LeMans and find that it seems to run out of gas if I lay on the throttle for too long. For most everyday driving it is fine.
Jared is offline
post #10 of 17 (permalink) Old 10-17-2014, 08:13 AM
Most Q-Jet problems are caused by the last guy who touched it. Very often they were "trick of the month club" subscribers who think they have some super secret insider information about how to do one and they know more than the company who engineered and built the carb. They're always wrong - on both counts.
Cliff's book is very good. If you can find an original unmolested QJet (hint - scour your favorite salvage yard for one from a full size "land yacht" car, not a performance car, as these are less likely to have been messed with), then sit down, read Cliff's book cover to cover before you ever get the tools out, study the parts you don't understand until you DO understand, then go through the carb yourself. I bet you'll be fine.
Best place to buy bushing kits?? OrbitOrange 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 10-09-2010 07:57 PM
Favorite Place to Buy efitzgerald1231 2004-2006 GTO General Discussion 8 12-25-2007 01:33 PM
Where is A good place to buy.... POOF 1964-1974 Tempest, Lemans & GTO General Discussion 1 03-12-2007 08:37 PM
Best place to buy goatfarmer 2004-2006 GTO General Discussion 2 06-29-2006 05:15 PM
