Best tire size for 15x7 on 67 convertible - Pontiac GTO Forum
post #1 of 8 (permalink) Old 08-28-2013, 10:27 AM Thread Starter
MrT
I need help figuring out what size will fit on my 67 convertible. It has 15x7 wheels with 4" backspace. I found a sweet deal on cooper cobras from discount tire and was wondering what sizes people have tried.
Looking at 235/60/15 or 235/70/15. I know the 60 series will fit but I'm not sure about the 70's
MrT is offline
post #2 of 8 (permalink) Old 08-28-2013, 01:23 PM
chuckha62's Avatar
Quoted: 18 Post(s)
I'm running 235/60's on mine. I have a weak spring on the left front though and it rubs occasionally on that tire. It doesn't do it all the time, but if it's going to, it does it when I am on the brakes making a right hand turn, like going into a driveway. I'm pretty sure, it's because of a weak spring.
chuckha62 is offline
post #3 of 8 (permalink) Old 08-28-2013, 02:53 PM Thread Starter
MrT
Does that give you about a finger width clearance on the back fender with the 60's?
Here's the specs from Cooper's website. I'm thinking of running the 60's. I just want to find a way to get some rake. I want the back to sit up a bit so it doesn't look so much like a boat.
P235/70R15
9.46" max sidewall to sidewall
27.9" max height
P235/60R15
9.15"
26.11"
MrT is offline
post #4 of 8 (permalink) Old 08-28-2013, 04:28 PM
chuckha62's Avatar
Quoted: 18 Post(s)
I have more than that in terms of vertical clearance, but I installed station wagon springs in my car when I bought it. The stock springs were sagging. By the book, the installed height of the wagon springs is only supposed to 3/4" more than the stock installed height. It does give it a nice stance though. A slight rake at most.
post #5 of 8 (permalink) Old 08-29-2013, 07:59 AM
SANDU002's Avatar
235 70 series will give you some rub on the front. If you go to 215 you should be fine. I am running 235x60 on my 15x7's with no issues front or rear, but my backspace is 4.5.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #6 of 8 (permalink) Old 08-29-2013, 09:35 AM Thread Starter
MrT
Sweet. Thanks gents.
I think I'll just do the 235/60's. I have to buy a matching set to get the sweet $75 rebate...
On another topic; it has the air shocks. A couple people told me to ditch them, I'm still on the fence. I don't mind them except I can't seem to get them to level out, side to side. Max is 35 psi??? Thats the only guidance i could find when I referenced the model number to the manufacturer website.
MrT is offline
post #7 of 8 (permalink) Old 08-29-2013, 11:41 AM
chuckha62's Avatar
Quoted: 18 Post(s)
I've run air shocks in the past and although I can agree they're not the best, they really aren't that bad. That being said, my car had them on it when I bought it and I got rid of them in favor of a pair of KYBs and station wagon springs in the rear. I like the ride height and gas shocks are WAAAY better for handling.
post #8 of 8 (permalink) Old 08-31-2013, 07:29 PM
no rub
On the '66 convertible with drum brakes, I'm running 15x7 Rally II rims with a 4 1/2" backspacing and 245 60r 15's with no rubbing issues.
gjones is offline
What size tire for a snow tire on my 04? BL3 Wheels and tires 5 11-26-2011 10:35 PM
Tire Size GuatoLT1 2004-2006 GTO General Discussion 4 01-02-2011 01:35 AM
Just got back from tire shop, 15x7 275/60/15 Max tire? HELP! GreenMachine 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-20-2010 05:33 PM
What is the widest tire on a 15x7 Rally II... ramairthree 1964-1974 Tempest, Lemans & GTO Wheels & Tires 1 04-23-2009 06:35 PM
