Best Valve Cover Gaskets for RA III Set Up? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 09-24-2015, 10:08 PM Thread Starter
Guys,
I am seeing that there are different thickness valve cover gaskets, for our Beloved 400 CID Poncho motor.
Have a now rebuilt '68 WS motor, with #48 heads and RA exhaust manifolds.
I want the thicker gaskets for the valve covers, but I am not seeing on the net who is the best manufacturer, the part number, and who sells them?
In the old days it was cork & rubber, and that may well still be, but I am seeing newer materials being used.
I.e. neoprene, solid core, etc.
FelPro was the standard, but not sure if still is...?
Can anyone please provide me with the info I am looking for?
Looking to buy some now.
Thanks in advance for the info.
Lfryklu
Lfryklu is offline
post #2 of 4 (permalink) Old 09-25-2015, 05:50 AM
Jared's Avatar
Quoted: 5 Post(s)
I would stick with the cork style gaskets. I have used the neoprene on a SBC and was never able to get them to be leak free. Switched back to the cork and never had a leak again. I don't remember the brand. It was whatever the local parts guy had (independent shop), but Felpro sounds right.
Jared is offline
post #3 of 4 (permalink) Old 09-26-2015, 03:41 PM Thread Starter
Found Em - FelPro VS50003AC - 1/4" RAM Air VC Gaskets
Found Em - If anyone else needs the info
Bolts are different length as well - longer for RA
Stock Application for RAM Air = 1/4" thickness is the difference
is Cork & Rubber Gaskets
FelPro VS50003AC - Valve cover gaskets
= 1/4" RAM Air VC Gaskets
The regular Stock Application for Non-RAM Air is:
FelPro VS50003C = 1/8" Valve cover gaskets
Lfryklu is offline
post #4 of 4 (permalink) Old 09-30-2015, 07:16 AM
allpawl66's Avatar
Also sold under part # 1627 Fel Pro = 1/4" thick
allpawl66 is offline
Are Fel Pro 1016 Gaskets OK For My Set-up Colorado67GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 07-16-2015 02:06 PM
Valve Cover Gaskets Oldeboy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-28-2013 09:21 AM
valve cover Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 15 10-12-2011 06:43 PM
whats a good set of valve springs to use? wytnyt 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 08-07-2008 07:16 AM
