Big step forward this weekend! - Pontiac GTO Forum
post #1 of 12 (permalink) Old 10-08-2011, 03:11 AM Thread Starter
69Goatee's Avatar
About six months ago I reached the summit of this restoration and started the downhill slide, finally turning the bolts, nuts and screws clockwise. Tonight I moved the jack stands from the frame where they have been for the last three years to the rear end and front control arms. I have done a few cars and trucks before, but this car is my first love. She has been through at least a dozen girlfriends, and now my wife(she totally gets what I am doing, so she is a keeper :-). I also started the part I love the most, runnin wires! Got my ignition box, coil and dizzy wired tonight. I think I will have it running and cam break in by Thankgiving. I left the brakes unfinished on purpose so I wouldn't drive it and get in trouble (neighbor is an A$$h*l#, would call the fuzz with a quickness)! I don't like to toot my own horn, but TOOT TOOT TOOT!! Pictures coming
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #2 of 12 (permalink) Old 10-08-2011, 10:03 AM
OrbitOrange's Avatar
PICS OR IT DIDN'T HAPPEN!
OrbitOrange is offline
post #3 of 12 (permalink) Old 10-08-2011, 10:06 AM
Congrats!!!! Man do I ever understand the feeling
post #4 of 12 (permalink) Old 10-09-2011, 02:10 PM
jetstang's Avatar
Woo HOO, 3 years, I bet you are itching to get it going. Best of luck!
Burning rubber since 1982!!
jetstang is offline
post #5 of 12 (permalink) Old 10-10-2011, 04:15 PM
post #6 of 12 (permalink) Old 10-11-2011, 10:21 PM Thread Starter
69Goatee's Avatar
Here are some pictures I took today. Frame, firewall and suspension were stripped and painted with POR-15. Check out the reflection of the valve cover on the smoothed passenger firewall. Click image for larger version
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
post #7 of 12 (permalink) Old 10-11-2011, 10:28 PM
jetstang's Avatar
Rear sump tank, planning for some HP? Nice build, getting close.
jetstang is offline
post #8 of 12 (permalink) Old 10-11-2011, 10:36 PM Thread Starter
69Goatee's Avatar
And a few more. The rollbar is an old school gasser three point, that I am relocating the rear down bar so I can use the back seat. I am mounting the coil, ignition box, relay and circuit breakers under the dash to keep the underhood clean and uncluttered.Click image for larger version
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
post #9 of 12 (permalink) Old 10-12-2011, 08:49 AM
Isn't that style coil oil filled?? Can you run it on it's side?
post #10 of 12 (permalink) Old 10-12-2011, 04:07 PM Thread Starter
69Goatee's Avatar
It's all good, the instructions say it can be mounted in any direction. Just not on the engine. I had to look it up, you had me worried. This is what the local roundy-roundy racers do, but they run two seperate ingnition systems.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
one step forward and two back... Instg8ter 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 03-05-2011 09:53 AM
69 GTO forward lighting harness retaining bolt IGOTGOAT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 09-26-2010 07:42 AM
next step mods chevyrida06 Engine Discussions 7 06-12-2010 10:28 PM
GA/FL III step inside !!!! EEZ GOAT Southeast 3 03-28-2006 08:24 PM
