Brake Adjustment Question - Pontiac GTO Forum
post #1 of 11 (permalink) Old 01-09-2019, 11:58 AM Thread Starter
Quoted: 12 Post(s)
Need to pull the drums off my 67 which are frozen on. Will start by loosening the adjusters. Here is the question.
If i do the drivers side rear when I put the tool in do I push down (which would make the little wheel go up and clockwise) or do I push up (which would make the little wheel go down and counter clockwise) It has been many years and cant remember
keiko is offline
post #2 of 11 (permalink) Old 01-09-2019, 04:48 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
This info is in the SM, really should have one.
Cheers
Name:	DRUM BRAKE ADJUST.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 11 (permalink) Old 01-10-2019, 05:22 PM Thread Starter
Quoted: 12 Post(s)
saw the picture (thank you) does this pic tighten or loosen the pads ?
keiko is offline
post #4 of 11 (permalink) Old 01-10-2019, 06:41 PM
Quoted: 349 Post(s)
It shows Fig. 5-7 that states it is for backing off the brakes - loosens them. They are not "pads", they are correctly called "brake shoes." Pads are for disc brakes.
post #5 of 11 (permalink) Old 01-10-2019, 10:04 PM Thread Starter
Quoted: 12 Post(s)
well i am totally confused, obviously if you have to back off the adjuster with a tool you must be loosing them. (counter clockwise) but i have seen 2 u tubes that show the same thing but it shows you turning the star wheel clockwise (pulling from bottom up)
keiko is offline
post #6 of 11 (permalink) Old 01-11-2019, 01:07 AM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
If
if your drums are stuck
one way to get slack is to take your drill ... "coal chisel "..grinder. or tool of choice
and knock the heads off the shoe anchor on the back side of the backing plate... looks like a nail head 2 of em
here is a picture of my drivers side on my Judge
this has helped me many times....also
leave the bleeder open a tiny bit and COVER the bleeder so it doesnt squirt to hard
or drain the system
allowing the wheel cylinder to collapse helps also
but
they are probably stuck rusted also if your havin shoe problems... and ALWAYS replace the rear cylinders
when your in there and all hardware..
Name:	April 1-15 2011 parts 130.jpg
ID:	117111   Click image for larger version
Name:	April 1-15 2011 parts 129.jpg
ID:	117113   Click image for larger version
Name:	April 1-15 2011 parts 138.jpg
ID:	117115   Click image for larger version
Name:	April -May1 2011 008.jpg
BLK69JUDGE is online now
post #7 of 11 (permalink) Old 01-11-2019, 11:43 AM Thread Starter
Quoted: 12 Post(s)
OK thanks, I think it is going to be a lot more than just backing off the adjusters
keiko is offline
post #8 of 11 (permalink) Old 01-16-2019, 07:36 PM
Quoted: 98 Post(s)
or drain the system
but
I have to disagree with this. As a 40-year auto tech, I've removed hundreds of stuck drums by pushing the locking pawl that rubs against the star wheel and lets it turn only in one direction inward with a thin screwdriver, while using another screwdriver or brake spoon to completely back off the adjuster. A couple of smacks with a hammer on the HUB of the drum, and it should come right off. Have NEVER needed to cut rivets and destroy parts in the thousands of brake jobs I've done. That said, I am in CA, where cars are never rusty.
post #9 of 11 (permalink) Old 01-18-2019, 12:27 AM
Junior has it! The adjusting pawl is outboard of the star wheel, and pushes down to tighten the brake adjustment. You must make the outboard side of the star wheel go UP to loosen, so the inboard side must go DOWN to loosen. You will lift the handle of your adjusting tool. Two adjusters are RH thread, two are LH thread!
Don't forget that you must push the adjusting pawl away from the star wheel to allow it to turn.
I recently had to use BLK69JUDGE's trick to disassemble a set of motorhome brakes. Wasn't easy, but it worked! If you had a leaky wheel cylinder, and the drum is rusted in place and will NOT rotate, this may be your only option. A new hardware kit is cheap, and money well spent.
Good luck.
Also, look closely at the front drums. Factory drums were locked to the hub by staking the wheel studs where they pass through the drum. You must pull bearings, and remove drum and hub as an assembly. If you're lucky, the drums have been replaced sometime in the last 50 years (!), and were replaced with a drum that is a slip-fit onto the hub.
Montreux is offline
post #10 of 11 (permalink) Old 01-23-2019, 03:21 PM
Quoted: 98 Post(s)
Good luck.
Another respectable disagreement here. The front hubs from the factory are swedged to the drums. You machine the drums on a brake lathe by installing inserts that fit into the bearing races. This assures a completely coencentric and true brake drum. When the wrong wheel studs are installed during service and the drum is no longer attached to the hub, it is almost impossible to turn the drum on a lathe and have it match up with the hub. You end up with a pulsating brake pedal. So, you are UNlucky if your front drums are loose from the hubs.....they were not designed to be.
Need help with rear drum parking brake adjustment BierManVA 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 02-10-2015 02:01 PM
Shifter Adjustment Question jpdog357 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-21-2009 07:09 AM
64 Parking Brake Adjustment Koppster 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 01-20-2009 09:15 AM
headlight adjustment HoldenGTO Service, Maintenance and Technical Discussion 7 12-21-2005 07:02 AM
height adjustment LaPuzza Service, Maintenance and Technical Discussion 5 07-14-2005 10:11 AM
