Brake bleed procedure? - Pontiac GTO Forum
 2Likes
  • 2 Post By Lemans guy
post #1 of 5 (permalink) Old 04-10-2019, 09:15 PM Thread Starter
the65gto's Avatar
Quoted: 12 Post(s)
Since I put disc on the front and still have drum on the back, I believe the bleeding procedure has changed to LF first, RF second, LR third and RR last?
the65gto is offline
post #2 of 5 (permalink) Old 04-11-2019, 07:04 PM
Quoted: 401 Post(s)
You want to start with the brake that is farthest away. RR, LR, RF, LF.
You want to "bench bleed" the master cylinder if you installed a new one. This is done first to get all air out of the MC. Then connect your lines and then bleed the brakes.
Check the MC reservoir after each cyl bleed as you do not want to go dry and have to do it again. I typically set the cover on top (not secured) of the MC to keep any brake fluid from splashing out.
post #3 of 5 (permalink) Old 04-12-2019, 03:57 PM
Quoted: 119 Post(s)
You also want to install a proportioning valve.
post #4 of 5 (permalink) Old 04-12-2019, 04:35 PM Thread Starter
the65gto's Avatar
Quoted: 12 Post(s)
Yes it is on there and lines connected. :-) I am at the point of deciding to remove the rear end and clean it up before connecting the rear brakes lines since it has 54 years of "stuff" on it.
the65gto is offline
post #5 of 5 (permalink) Old 04-12-2019, 07:56 PM
Lemans guy's Avatar
Quoted: 79 Post(s)
I like to use the Dot 4 fluid...it is compatible with Dot 3...they can be mixed....valvoline even sells a Dot 3/4.....
Dot 4 has a higher boiling point and since you are starting a new system......better to have temperature on your side!
the65gto and PontiacJim like this.
Lemans guy is offline
minor brake issue likely just not bleed all the way down... virginiavenom 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 10-03-2011 07:46 AM
Installing master cylinder, bench bleed procedure? olde-goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-26-2010 05:37 PM
Proper cold-weather start procedure ejj 2004-2006 GTO General Discussion 16 02-11-2007 11:00 PM
Best tuning procedure for radios best sound quality performance IH2ton6cyl Service, Maintenance and Technical Discussion 7 11-11-2004 12:43 AM
special oil change procedure, huh ? westell Service, Maintenance and Technical Discussion 7 11-03-2004 09:55 AM
