build sheet info - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-25-2017, 09:26 AM Thread Starter
build sheet info
Is there a link to a build sheet decoder or identifier for the 1970 BUILD sheet for the GTO? I can find VIN and Data plate decoders, but cannot seem to locate one for the build sheet. I have my build sheet but would like to decode it to see what was scheduled to be on the car. And i would like to know the production date for the car at the same time. can you help me?
truetriplex is online now
post #2 of 4 (permalink) Old 07-25-2017, 10:43 AM
pjw1967's Avatar
You can see most of it on the sample page.
https://www.opgi.com/gto/DT00366/
pjw1967 is offline
post #3 of 4 (permalink) Old 07-25-2017, 11:03 AM
There are no GTO buildsheet decoder sites, That would be a massive undertaking & unfortunately, with the errors that are on many current GTO decoding sites, the number of errors on a build sheet site would be most likely many times more.
The above link to OPGI notes a generic order sheet, not a plant specidic deck writer printed build sheet. 1970 Arlington builds used the large (8 1/2 x 11) style 1970 build sheet. On this style buildsheet, the scheduled build date is the top left fand corner. If the printed codes are legible and not faded, feel free & post a copy, or drop me a PM & I should be able to decode whatever boxes you have questions to. In regards to the car possibly being built with the WT7 option, when was the body built? The body build will be noted on the trim tag.
post #4 of 4 (permalink) Old 07-25-2017, 01:42 PM Thread Starter
Pinion Head - sent you PM.
Where would the build sheet be in a 72 gto? markvit Member Introductions 3 02-28-2013 04:30 PM
build sheet revup47 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-04-2010 08:23 AM
build sheet question ? abodybrad 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-27-2010 09:37 AM
I found myself a build sheet Priest 1964-1974 Tempest, Lemans & GTO General Discussion 6 03-22-2010 03:06 PM
build sheet 1bad69 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 07-14-2008 10:35 AM
