Can you explain how to fix my GTO blinker - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-27-2013, 04:37 PM Thread Starter
So I was driving in the 74 goat today and when I turn my blinker was catching funny and I could feel it in the steering wheel. For example at the point where the blinker should click off - I get some resistance in my steering wheel like I am hitting something then just push past it and it clicks off like normal. Now with that my blinker "switch" or whatever you want to call it (The stick coming out of the steering wheel for blinkers) Is real loose and jingly. How can I remedy this..Not the most knowledgeable on blinkers or blinker mechanics. Thanks!
74guy is offline
post #2 of 2 (permalink) Old 09-28-2013, 09:08 AM
68greengoat's Avatar
It could be the screw holding the arm is loose...... I don't know what your wheel looks like, but, you're going to have to take the cover off to get at the screw. The screws holding the cover on may have to be accessed from the back of the wheel.... Just guessing...
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
66 GTO Blinker/Brake Light problem Indecision 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 13 05-24-2012 07:13 AM
Please explain the degrees of gloss like 30 or 60 67blackgoat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 12-09-2011 09:07 AM
Please explain the 1st to 4th indicator on a manual 06 GuatoLT1 Drive train, suspension, alignment and brakes. 6 09-04-2009 04:12 PM
Blinker problems, I need advice!!! GTOFlyer Service, Maintenance and Technical Discussion 2 11-18-2008 12:35 PM
Just Curious, Please Explain RED68GTO 2004-2006 GTO General Discussion 13 11-27-2004 10:55 AM
