carb connections - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-02-2011, 01:10 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
carb connections
Got my 67 Rochester back from "The Carb Shop".
WOW............awesome work for a good price.
Anyway, the big fitting on the back, does this go to the brake booster fitting?
If not where does it go?
Also , why is the dam connection so big?
I think it has a threaded fitting,and of course I'm missing the hose.
thanks in advance
Topkat is offline
post #2 of 4 (permalink) Old 03-02-2011, 01:27 PM
Quoted: 102 Post(s)
Yes, it goes to the brake booster. There is a steel pipe with a male fitting that goes into the female fitting at the carb base. The other end of the pipe goes to a length of rubber hose that plugs on to the booster connector. The pipe is curved towards the booster. It's BIG because you need a big vacuum supply to the booster at all times.
post #3 of 4 (permalink) Old 03-02-2011, 01:51 PM Thread Starter
Topkat's Avatar
Are they metal lines?
that's all I see in the catalogs.
ty
Topkat is offline
post #4 of 4 (permalink) Old 03-05-2011, 11:52 PM
metal tube line into metal carb fitting, then rubber fuel hose from tube end to booster plastic vac. fitting.
pontiac is offline
starter selenoid connections Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-26-2011 04:43 PM
PCV connections Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 02-23-2011 06:28 AM
smog pump connections on 67 Goat Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-15-2011 09:16 PM
Confused About Fuel Pump Connections peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-03-2010 12:25 PM
Battery Tender...Connections... silversport Service, Maintenance and Technical Discussion 8 02-11-2009 10:06 PM
