carter q-jet - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-22-2012, 01:08 PM Thread Starter
carter q-jet
i have an old carb that i think is off a pontiac gto. it used to be on a 67 gto. don't know if it was original to the car. I can't find any tags. the only thing i find is stamped into the linkage side of it and it say mfg. by carter for gmc. on the very back of it carb on the body is stamped J35 and beside that is the no's 7047687. that is the only ones i can find on it. is it a 67 or later year? can you help me out on this.
redbubba is offline
post #2 of 4 (permalink) Old 05-22-2012, 05:14 PM
chuckha62's Avatar
Quoted: 18 Post(s)
Interesting... according to Cliff Ruggle's book, it's a '77 carb., non-Calfornia. The "8" in the 6th position denotes either Checker motors, or marine. That's a little odd, but hey...who knows.
chuckha62 is offline
post #3 of 4 (permalink) Old 05-22-2012, 05:32 PM Thread Starter
thanks chuckha62 its a lot more than i knew to begin with. you are probably right. it is a 77
redbubba is offline
post #4 of 4 (permalink) Old 05-30-2012, 04:10 PM
rickm's Avatar
Quoted: 5 Post(s)
that carb is made by carter, but it has a rochester part # wich i recall was common in the'70s when i worked at a auto parts store. im sure it has more applications. carb kit instruction sheet will list all. rickm.
rickm is offline
Carter AFB problems KingJacobo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-08-2011 02:14 PM
help with 66-67 carter carb fasterfiero 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 11-29-2011 12:54 PM
Carter AFB help trialsmm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-07-2011 03:29 PM
What is a Carter 4887S C5? Luiz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-21-2008 06:57 PM
