Clutch issues - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-17-2008, 04:22 PM Thread Starter
Clutch issues
Hello everyone, I recently put a new pressure plate and disk in my 70 w/out surfacing the flywheel. Once completed, whenever I would reach the release point it would not only chatter but make a terrible raspy sound. I know you're all thinking the disk must've been installed backwards; however, I just pulled it all back apart and it wasn't. The springs on the disk were riding on the bolt heads of the flywheel even though it was installed correctly. I took the entire kit + flywheel back to Napa for examination, and the recommendation was to order a new flywheel and re-check the tolerances. I guess my real question is if the flywheel is this far out of spec, why didn't it make noise with my old worn out disk? FYI engine is a 455, M21, w/ Hays flywheel resurfaced once 10 years ago. The Napa rep believed the flywheel bolts to be correct, very shallow, they look almost like studs w/ a nut screwed half way on
Just realized I probably should have posted this in the tech section, can a moderator please move if necessary.
Thanks in advance
1970 gto
cole455 is offline
post #2 of 6 (permalink) Old 04-17-2008, 04:45 PM
Welcome to the forums.
If the bolts of the flywheel are interfacing with the disk, then the disk/pressure plate must be the wrong ones for that flywheel. Perhaps the flywheel is off another year/ application?
post #3 of 6 (permalink) Old 04-17-2008, 04:56 PM Thread Starter
It's very possible the flywheel could be wrong. I just ordered one from year one, it appears the same as my old one, but it's tough to tell from the thumbnails. It measures 2-3/4's for the crank just like the ones advertised. I guess we'll see.
1970 gto
cole455 is offline
post #4 of 6 (permalink) Old 04-17-2008, 06:01 PM
Aramz06's Avatar
Send a message via AIM to Aramz06
haha rukee has mastered these GTO's
-LSS Shifter
-Resonator Delete
-Flowmaster 44 Series Mufflers
1 of 475
Aramz06 is offline
post #5 of 6 (permalink) Old 04-18-2008, 02:04 PM
I would say...A parts match issue. Possibly the wrong diamater new clutch. It is pretty difficult to cut a flywheel that much...especiually since you didn't cut it at all.......Eric
Eric Animal is offline
post #6 of 6 (permalink) Old 04-18-2008, 02:55 PM
Quoted: 118 Post(s)
It's simple: the flywheel is too shallow at the flange area for the new disc. IF the springs are hitting the bolt heads, and the springs on the old disc did not, I would blame the new disc. If, as you say, you are unsure of the flywheel's origin, then the flywheel AND old disc might be some other application. So, a new GTO-spec clutch may not work. The new flywheel should fix your problem. You could measure the clutch disc heights to check. I would also check the depth of the new Pontiac flywheel and compare it with the old one. You'll get it fixed. BTW: I've had good luck with old flywheels that I didn't want to remove to machine by doing the following: Check runout with a dial indicator, if not warped, deglaze flywheel with one of those air powered brillo discs. Clean with brake-clean. Works well, and won't thin out a flywheel. Won't work on a cracked or warped flywheel, though. Good Luck.
Jeff
Buying a GTO, What's up with the Clutch? apicia 2004-2006 GTO General Discussion 9 03-12-2007 05:57 PM
Clutch Extension GTO_Gregory Interior Discussions 4 10-28-2006 08:31 PM
New GTO Clutch Question Aceofaces Service, Maintenance and Technical Discussion 6 10-03-2006 09:58 AM
Clutch Problems GoatBoy37 Service, Maintenance and Technical Discussion 4 08-26-2006 12:06 AM
Clunk when Lifting Clutch daveinsa 2004-2006 GTO General Discussion 6 06-17-2005 08:53 AM
