Coil Spring Size? - Pontiac GTO Forum
post #1 of 1 (permalink) Old 11-17-2013, 01:12 PM Thread Starter
Coil Spring Size?
looking for alittle help. I installed wheel hop stoppers now that my upper control arms are sitting higher, i end up hitting the upper control arms on a bump. Regular shocks do not come into play before you hit. I installed air shocks which is not the answer. Now that i have the car higher to avoid the bottoming out my springs do not come into play. Do i put in taller springs then different shocks any help would be appreciated.
69-GOAT is offline
Coil Spring AC vs Non-AC young99 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-27-2013 08:58 PM
Good Coil Spring Info leeklm 1964-1974 Tempest, Lemans & GTO General Discussion 4 05-11-2012 04:02 PM
coil spring mounts crazyskinner 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 04-23-2011 09:23 PM
Coil spring for '04 GTO crebrosseau Drive train, suspension, alignment and brakes. 1 08-18-2010 11:41 PM
Coil spring id ric80low 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 02-18-2010 10:27 AM
