coils - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-18-2011, 03:38 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
coils
Im shopping for ignition coils for my 67 Goat.
I have a new remanufactured point type distributor.
Kinda want to do the Petronix 2 system.
The ads for the coils mention ballast resistors.
What's that about? Do I have one?
thanks as always
Topkat is offline
post #2 of 2 (permalink) Old 03-21-2011, 12:41 PM
Ballast resistors were used to drop voltage to the coil during normal run conditions. Normal system voltage was not needed and caused rapid wearing of the ignition points. GM used a resistance wire to the + side of the coil to drop the voltage down. Some years had a second wire to the coils + side, this wire lead to the starter solenoid and was a bypass to allow full voltage to the coil during engine start. The theory being that when the starter was engaged the voltage would already be low and the ignition system needed all the power available. The original 67 wiring should have had two wires, according to the books I have. A black and a white braided, the latter the resistance wire. I'm not sure what the requirements are for the point elimination kits, my guess is that they use full power, and if so would require running a new wire from a switched ignition on source as well as from a source during engine start which should be the exsisting black wire. Check the "point kit" for wiring details. Have a volt meter ready and double check for power, in both positions, start and run.
JustAl is offline
Megan's coils/springs Suspension Kit firebird Drive train, suspension, alignment and brakes. 13 03-05-2011 09:23 AM
MSD Blaster Coils raspantienator Engine Discussions 12 07-20-2009 05:41 PM
MSD's LS2 Coils tbyrne Engine Discussions 2 01-04-2007 07:54 AM
Msd Coils For Ls2 MSTNGKILLA Engine Discussions 5 08-06-2006 08:26 PM
