converting a 64 4brl. to a tripower - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-16-2009, 03:06 PM Thread Starter
marks64's Avatar
I'm considering switching out my 64 GTO 4brl for a tripower and had a few questions on the vacuum lines. I can see that most of the vacuum lines are fairly straight forward - power brakes, advance etc. But, I'm a little confused with the the vacuum pipe to the automatic transmission on of the 4brl. It's a steel pipe and it looks like I'd have to cut it and reconnect it. Any advice? Any advice on all the vacuum lines and conversion to the tripower? Does anyone out there know of any diagrams available that might help?
Thanks!
marks64 is offline
post #2 of 5 (permalink) Old 06-16-2009, 07:07 PM
That steel line to the tranny just gets connected to a manifold vacuum supply. You can bend it around a bit to make it fit to it's new location.
post #3 of 5 (permalink) Old 06-17-2009, 12:25 PM
Quoted: 100 Post(s)
I agree. Or, remove the line and use a vacuum hose and a couple of brass fittings. Then, if you go back to original, you'll have the "correct" vacuum line. Nothing much simpler than the vacuum schematic for a '64 GTO.....take a photo of all the hoses (all 2 or 3 of them) and hook them up in a similar matter on the 3x2 set-up. You will be amazed at the power gain you're going to get with the tripower! Good luck.
post #4 of 5 (permalink) Old 06-17-2009, 03:56 PM Thread Starter
marks64's Avatar
Thanks for the info!
It seems simple enough. Thanks for the quick response.
marks64 is offline
post #5 of 5 (permalink) Old 06-18-2009, 10:46 AM
6T5GOAT's Avatar
Unless you are going for a concourse restoration why not switch the linkage over to the 65 mechanical linkage? Thats what a lot of people did back in the 60's. I understand this was a better set up than the vacum operatated linkage.
Johnny
6T5GOAT is offline
Tracking down Dad's 1964 tripower GTO doebs_99 1964-1974 Tempest, Lemans & GTO General Discussion 5 05-15-2009 11:46 AM
Swapping a 66 from the standard 335 to the Tripower? xconcepts 1964-1974 Tempest, Lemans & GTO General Discussion 11 01-12-2009 03:38 AM
Converting open rear to posi PaulPaladin 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-11-2006 12:25 PM
68 tripower intake wannagofast 1964-1974 Tempest, Lemans & GTO General Discussion 2 09-06-2005 03:41 PM
