converting drum to dics info? help? - Pontiac GTO Forum
post #1 of 19 (permalink) Old 11-16-2014, 08:55 PM Thread Starter
I am going to attempt to convert my 68 GTO CONV. to disc brakes.
looking to see if there is another A-body car I can use to achieve this instead of buying a kit.
there is lots of salvage yards in the area where I live, so why not use them.
what im looking for is a simple way to take brake parts off a car that will bolt up on my 68. Is there any vehicle out there that is a basic unbolt, bolt on car?
or do i have to mixmatch parts to accomplish this?
has anyone done a salvage yard conversion?
thanks for the help, i know that this topic has most likely been discussed on here before but im not good with searching forums ha. thanks again.
perrystroke is offline
post #2 of 19 (permalink) Old 11-16-2014, 10:26 PM
Quoted: 106 Post(s)
You can do it junkyard style and you have to get the spindles and add a booster to your master.
Here is a thread that answers some of your questions.
Also if you have 14" rims you have to make sure they are compatible.
I have 15" Rally IIs and just bought the conversion kit from Summit, all new stuff including the spindles and master I didn't want to waste a bunch of time screwing around at Pick A Part getting parts and rebuilding them.
https://www.gtoforum.com/f50/68-disc-...89/index2.html
http://www.summitracing.com/parts/sum-bk1201/overview/
Goat Roper is offline
post #3 of 19 (permalink) Old 11-17-2014, 05:19 AM
We just did a front disc/dual master cyl conversion on a 64. We ended up purchasing a kit from a reputable co.. ( after trying to mix/match new parts that supposedly would work)Even then we had some customizing to do, on a supposed bolt on appl. . It was no surprise or problem, ( just time) my point is=time vs headache vs $. you may want to ponder. Good luck w/ conv. My customer really like shis.
motoman is offline
post #4 of 19 (permalink) Old 11-17-2014, 06:59 PM Thread Starter
who has the best bang for your buck when it comes down to a new bolt on system? also when you get a system does it come with everything you need? or is there the "things they dont tell you, you need"?
post #5 of 19 (permalink) Old 11-17-2014, 07:39 PM
Quoted: 106 Post(s)
Mine came with everything and took about 6 hrs. to do.
There are different kits and some won't fit 14" wheels but there is a kit for them also.
You will need a kit that has the spindles, you can get stock, drop etc.
I went with stock.
post #6 of 19 (permalink) Old 11-17-2014, 09:00 PM Thread Starter
what year GTO is yours and what company did you use for your kit? maybe looking into getting a 4 disc kit, not sure yet
post #7 of 19 (permalink) Old 11-17-2014, 09:23 PM Thread Starter
also I do not have power brakes, did you convert yours to power and what did you have to do to do that
post #8 of 19 (permalink) Old 11-17-2014, 09:36 PM
Quoted: 106 Post(s)
Mine is a '67 and this is the kit I bought.
Minimum wheel diameter is 15" on this one.
Here is the other one for 14" wheels.
http://www.summitracing.com/parts/sum-bk1203/overview/
You really don't need the discs on the back since most of the stopping power is in the front.
Both of these kits will fit your '68.
post #9 of 19 (permalink) Old 11-17-2014, 09:38 PM
Quoted: 106 Post(s)
Look at the kits, they have a booster and master included you just need to pull vacuum from the manifold and you have power brakes.
My car came from the factory with PB so I already had the vacuum hose.
post #10 of 19 (permalink) Old 11-18-2014, 06:31 AM Thread Starter
wont the booster have a hard time bolting up since it did not come from the factory with one?
thanks again
69 converting to HEI 69GTOCONVLOVER 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-19-2014 10:52 PM
Converting GT 2 GTO Member Introductions 0 10-22-2011 06:33 PM
Converting Drum brakes to disc Welby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-25-2010 10:21 PM
Converting Drum Brakes to Disc on 65 MikeMcGinn 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 22 04-21-2009 09:18 PM
when converting from 04 to 05 exhaust... 7moon12 2004-2006 GTO General Discussion 3 04-27-2008 12:27 PM
