core support - Pontiac GTO Forum
post #1 of 9 (permalink) Old 07-20-2011, 07:25 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
core support
Is the top front of the core support supposed to be flat?
this sure don't look right
thanks as always
ID:	11821   Click image for larger version
ID:	11822   Click image for larger version
Topkat is offline
post #2 of 9 (permalink) Old 07-20-2011, 09:41 AM
Pontiacpurebrred's Avatar
Hey TK,
I do believe your core support is a tad bit warped.
See example here....
1966-67 Pontiac GTO Lemans core support | eBay
Pontiacpurebrred is offline
post #3 of 9 (permalink) Old 07-20-2011, 09:55 AM
68greengoat's Avatar
It buckled from all the heat and humidity.....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #4 of 9 (permalink) Old 07-20-2011, 11:46 AM
likethat's Avatar
Here are some shots of my 66 A/C core support and our Kat helping TopKat:
67 GTO H.O. Convert 4spd
likethat is offline
post #5 of 9 (permalink) Old 07-20-2011, 03:27 PM Thread Starter
Topkat's Avatar
Awesome, thank you guys.............and Kat!
looks like a job for my BFH!!!!
TK
Topkat is offline
post #6 of 9 (permalink) Old 07-20-2011, 06:57 PM Thread Starter
Topkat's Avatar
Are there supposed to be spacers between the header panel and the and the core support bolt down points?
thanks as always
Topkat is offline
post #7 of 9 (permalink) Old 07-20-2011, 07:11 PM
Ideally, NO....You might want to talk to Randy (05GTO). I beleive he replaced the rad/sup in his GTO with a repro unit. Something to consider, if it fits your budget.....E
Eric Animal is offline
post #8 of 9 (permalink) Old 07-21-2011, 01:00 PM
there should be bushings down where the radiator support bolts to the frame I believe, but otherwise no. but yea, you are a little bended. my channel on the bottom is open down and not up, but otherwise is identical to the one "likethat" posted.
virginiavenom is offline
post #9 of 9 (permalink) Old 07-21-2011, 02:53 PM
Quoted: 103 Post(s)
Your support needs to look "likethat"'s. I would get another one.....you'll be fighting body alignment issues for days with that one. Or, borrow a straight one to use as a comparison, remove yours, and blacksmith it back into shape. You need a good one to use as a reference, though, IMO.
core support Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-24-2011 08:35 AM
Core Support Mount Holes mighty454 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 10-20-2010 04:07 PM
69 Radiator core support help!!!! 369GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-10-2010 08:39 PM
1966 core support hardware 1966Dave 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-15-2009 08:56 PM
