Correct Oil Fill Quantity - Pontiac GTO Forum
post #1 of 11 (permalink) Old 02-26-2019, 03:45 PM Thread Starter
gnsjoy's Avatar
66 with WS engine. Owners manual says 7 quarts with filter change. Dipstick says 5 qts (can not verify dipstick is the correct one). Pontiac Shop Manual say six qts. Which is correct?
gnsjoy is offline
post #2 of 11 (permalink) Old 02-26-2019, 03:49 PM
As far as I know, most of the pontiacs from the “muscle car” era take 6 qts. My 68 GTO takes 6. I would fill it slowly and keep checking the stick. I don’t know if an oversized oil pan was an option on any of them.
Bill E is offline
post #3 of 11 (permalink) Old 02-26-2019, 05:38 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
AMA Spec sheets show 6 (less Filter refill), so 7 with new full filter.
Your dipstick in not correct.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 11 (permalink) Old 02-26-2019, 08:51 PM
Quoted: 347 Post(s)
Interesting. My '68 manual states 5 quarts in the pan Plus 1 quart in the filter for a total of 6 quarts. My 1966 AMA 389 engine spec says 5 quarts -pan, plus filter which is 1 quart for a total of 6 quarts. Chilton states 5 quarts plus 1 for the filter for a total of 6 quarts.
All the V8 Pontiac cars I had used 5 quarts plus 1 in the filter for 6 quarts.
Here is another thread on the same question- https://www.gtoforum.com/f50/oil-type-capacity-20669/
post #5 of 11 (permalink) Old 02-27-2019, 05:53 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Amazing how convoluted all these manuals/books are.
1966 AMA TEMP/LEM 6+
1966 AMA GTO 6+
1966 FACTORY SERVICE 5+
1966 MOTORS 5+
I think its safe to go with the consensus of 6
Name:	66 AMA TEMP-LEM OIL CAP PG.jpg
ID:	117861   Click image for larger version
Name:	66 AMA GTO  OIL CAP PG.jpg
ID:	117863   Click image for larger version
Name:	66 SM TEMP-LEM OIL CAP PG.jpg
ID:	117865   Click image for larger version
Name:	66 MOTORS TEMP-LEM OIL CAP PG.jpg
post #6 of 11 (permalink) Old 02-27-2019, 05:58 PM
Quoted: 347 Post(s)
1966 AMA GTO 6+
1966 MOTORS 5+
Interesting.
I do not have the AMA Spec for year 1965, but, my AMA Spec dated 9-2-65 for year 1966 GTO clearly shows 5 quarts plus filter where your states 6 quarts plus filter.
Looking at the 1964 AMA Spec for the Lemans/GTO Option, it also states 5 quarts plus filter.
The 421 Super Duty used a 6 quart pan plus filter.
I have seen this in the specs on the Plymouth Fury. Sometimes they will use the previous year specs on a current engine/car that is still in production. Even options are listed for the new up and coming year and never made available. I suppose that the car specs may have to be submitted at a certain time frame to the AMA and to meet these time frames, they may use some previous engine data to fill in the blanks for the current model engine.
I can also see someone not paying attention when they write the specs and did not notice or understand the fine print "less filter - refill (qt.)"
post #7 of 11 (permalink) Old 02-27-2019, 06:23 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
The AMA sheets I've shown above are the 9-2-65 for 1966 pages.
post #8 of 11 (permalink) Old 02-28-2019, 05:53 PM
Quoted: 347 Post(s)
Yep, and why I said "interesting, my AMA 9-2-65 for 1966 page shows 5 quarts."
Name:	9-2-65 AMA Spec.JPG
post #9 of 11 (permalink) Old 03-17-2019, 11:31 AM
Quoted: 98 Post(s)
The pan got changed around 1968-69 to a lower capacity. (Has a drain plug on the side instead of at the rear). My '65 389 holds 6 quarts loaded for bear, and my '67 GTO with it's original engine, pan, and dipstick holds 7 quarts. Always has.
post #10 of 11 (permalink) Old 03-17-2019, 05:15 PM
Quoted: 347 Post(s)
Interesting. The 1967 AMA specs do indeed state 6 quarts plus filter. Looked at the 1968 AMA specs and it goes back to 5 quarts plus filter.
Is the '67 pan unique or are the AMA specs unreliable? My Factory Service Manual for 1968 also states 5 quarts plus filter.
cant fill tank fast? ricekiller848 Service, Maintenance and Technical Discussion 9 12-19-2007 05:29 PM
What is the real oil fill quantity for the LS2? bergenfelter Service, Maintenance and Technical Discussion 2 08-17-2006 10:51 PM
Radiator Fill tjblake 2004-2006 GTO General Discussion 4 07-18-2006 07:26 PM
What is the correct M6 fill volume??? cat1055man Service, Maintenance and Technical Discussion 10 02-05-2006 01:22 AM
Fuel fill problem Duck916 Service, Maintenance and Technical Discussion 8 12-17-2004 05:03 PM
