Correct spark plugs - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-07-2009, 01:59 PM Thread Starter
Correct spark plugs
Hello. Newbie here. I've come across some spark plugs which I believe that I bought for my 68. They are Champion UJ-10Y plugs. Will these fit or is there a web link where I can potentially find the information?
Goatrivergoat is offline
post #2 of 5 (permalink) Old 08-08-2009, 12:17 AM
correct plugs
Those are plugs for your pontiac, but depending on how your engine is built.
thats a fairly cold plug
to keep it simple the number in this case the 10 tells how "cold a plug will run" most high comp motors and race motors need a cold plug to reduce pre-ignition in hotter more powerful engines.
hotter 14
hot 12
cold 10
colder 9
most "street" motors run on rc12 for instance.
i have a 12 to 1 500+ HP motor, i would use 9 (RC 9YCC )or likely a 10 (RC 10YCC )
silky58 is offline
post #3 of 5 (permalink) Old 08-08-2009, 02:41 PM Thread Starter
Correct plugs
Thank you for the prompt response. I found my ebay sheet with the description. It was: '1959-1968 Pontiac Champion Spark Plugs Royal Bobcat GTO'. Based on your response, being a colder plug would coincide with the Royal Bobcat claim-I guess. At least I know they will fit; how it runs will be another matter.
post #4 of 5 (permalink) Old 08-08-2009, 06:09 PM
Quoted: 102 Post(s)
The standard plug was a J12 in Champion (if you used Champion instead of AC). J11's and J10's were used by Royal Pontiac and others FOR STRIP USE. They're too cold for driving around on the street. They will fit, and they will work, but they'll tend to load up while idling around, etc.
post #5 of 5 (permalink) Old 08-10-2009, 01:27 AM Thread Starter
Good to know. Thanks for responding.
aftermarket spark plugs BlueBomber Service, Maintenance and Technical Discussion 13 01-06-2009 08:09 AM
E3 Spark Plugs VS Bosch Plat +4 NJG8GT Engine Discussions 6 05-11-2008 01:23 PM
What spark plugs for the ls2? Ozzhead Service, Maintenance and Technical Discussion 22 02-18-2008 12:23 PM
Spark Plugs? NJG8GT Engine Discussions 6 02-14-2008 09:51 AM
performance spark plugs and Royal Purple.... huntermech Engine Discussions 2 12-10-2007 07:29 PM
